will i need EF or DA stainless steel brake lines for my DA brakes on my EF?
Old 04-10-2005, 09:43 PM
93formula's Avatar
Default will i need EF or DA stainless steel brake lines for my DA brakes on my EF?
just wonering if there the same or will i need DA SS brake lines???
Old 04-10-2005, 10:12 PM
90sohcHATCH's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (93formula)
depends on what brakes u have...order the DA ones first i believe that would work
Old 04-10-2005, 11:11 PM
93formula's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (90sohcHATCH)
im using the DA brakes off of a 92
Old 04-11-2005, 08:16 AM
JohnnieChimpo's Avatar
I ran 90-93 Integra front and rear discs on my 89 HF
I bought a stainless line kit for a 91 CRX Si.
I have only installed the rears but they seem to fit fine.
The Integra lines might be a little longer. The CRX ones seemed like they needed a tiny bit more, but they do fit fine.
Another thing to remember here is, I did not install the whole rear suspension from the DA. I only installed the spindles onto my CRX arms.
As for the fronts, the caliper on the DA is farther away from the center of the wheel than a CRX Si so the line on the front can actually be shorter.
Since I didn't know till I actually did it, I'll tell you since you might not know either. The fittings on the 4 wheel disc brakes are all the same. The lengths are probably different, which is causing there to be more than one stainless line kit.
Old 04-11-2005, 08:37 AM
mahatma's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (JohnnieChimpo)
I'll be doing this entire swap this weekend. I ordered DA lines. I've heard that the stock drum lines won't bolt up to the teg calipers......
will let you know for sure next monday
Old 04-11-2005, 09:09 AM
Crazy Honda Guy
Deetz's Avatar
i have DA rear brakes on my 89 crx, i had to use the DA lines for my car.
Old 04-11-2005, 02:38 PM
93formula's Avatar
Default Re: (Deetz)
thanks for the replies guys, ill wait fory your input mahatma, but im assuming ill need DA brakes lines.
Old 04-19-2005, 08:38 AM
mahatma's Avatar
Default Re: (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies guys, ill wait fory your input mahatma, but im assuming ill need DA brakes lines.</TD></TR></TABLE>
DA lines fo sho
Although for a 4 wheel brake swap I must admit I'm underwhelmed by the difference in performance. In fairness, I simultaneously swapped 16" wheels in place of the 13" steelies, and neglected to change the brake booster (used EX master cylinder & DA prop valve though).
And WOW is the alignment off now. I was scurred to even have it on the road. Wanders all over the place, I'm wondering if maybe a trailing arm isn't bent or something......it's being aligned right now, we'll see how it all pans out.
Rear discs sure look purdy though
Old 04-19-2005, 03:54 PM
93formula's Avatar
Default Re: (mahatma)
alignment is a must because youve taken your whole suspension apart, theres no way it would have gone back in the same spots. let me know how it is after the alignment.
i picked up a set of brembo stopcheck x drilled rotors myself from the sponsors section.
Old 04-19-2005, 05:43 PM
EL Vap133's Avatar
I have DC front brakes with DA knuckles, and crx si rear disc brakes and I am running 90-91 CRX Si steel braided brake lines.
Old 11-07-2005, 06:38 PM
Stoich's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (EL Vap133)
So since i already have SS lines on my 90dx hatch i can use them even when i switch to the Integra front brakes?
Old 11-07-2005, 07:04 PM
EL Vap133's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (Stoich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">So since i already have SS lines on my 90dx hatch i can use them even when i switch to the Integra front brakes?</TD></TR></TABLE>
For the front, yes.
Old 11-07-2005, 07:41 PM
Rukusmasta2's Avatar
wheres a good place to buy then lines
Old 11-08-2005, 01:45 AM
Stoich's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (Rukusmasta2)
Ok last question
I dont need the porp valve right? Im leaving the stock drum setup in the rear.
Old 11-08-2005, 05:35 AM
spatula's Avatar
for integra front brakes do you just swap the front hubs?
Old 11-08-2005, 07:07 AM
CRX Toad's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (spatula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spatula &raquo;</TD></TR><TR><TD CLASS="quote">for integra front brakes do you just swap the front hubs?</TD></TR></TABLE>
Nope have to swap entire knuckle.
Old 07-03-2008, 04:12 PM
crx2nr822's Avatar
Default Re: will i need EF or DA stainless steel brake lines for my DA brakes on my EF? (CRX Toad)
I have a question, I am putting DA front brakes (A-arm and everything) on my 88 HF crx and I just ordered the SS brake line kit that says its for 89-91 w/ rear drums, will this still work on the front brakes? I am wondering why it doesnt say 88-91 on the application chart.....is there something different about the 88 front brake lines?
Sorry to bring back such an old thread BTW
CIVIC9922
05-18-2011 03:17 PM
///Mathew
03-09-2011 05:05 PM
nudvl
09-18-2006 02:10 PM
tmeracz
04-27-2006 09:50 PM
POLLO
02-23-2002 03:18 PM
Quick Reply: will i need EF or DA stainless steel brake lines for my DA brakes on my EF?
