CEL code 0
Old Nov 15, 2011 | 10:27 PM
91efbluehatch's Avatar
Default CEL code 0
my cel is throwing code 0 at me
thermostat ground is clean and secured.
i read somewhere on pgmfi.org that you can unjump a wire and check to see if the CEL is still on.
http://forum.pgmfi.org/viewtopic.php?f=2&t=22333
^its not the same as mine, but is this possible to do with my PR3 obd1 ecu??
which wires would i need to check?
also i pulled the plates off and visually inspected the boards and nothing seemed out of place
Old Nov 15, 2011 | 11:07 PM
tonylovesjdmEF9's Avatar
Default Re: CEL code 0
code 0 is bad ecu bruh if my mind isnt ****ing up lol
Old Nov 16, 2011 | 12:59 AM
crx_si-r's Avatar
nope, your right. if you jump the connector and you get a solid light that doesnt flash. you have a bad ecu
Old Nov 16, 2011 | 02:57 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Not necessarily... Regardless, it helps to search... from a previous thread still on the first page even.........
Originally Posted by N3va3vaSatisfi3d
I was going to go on and on with a lengthy response but then after 5 seconds of searching I found this...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/no-start-solid-cel-heres-what-i-did-tons-pics-2458280/
Start from the top and work your way down... I do realize this How-TO is for a '92-00 Honda but many of the steps are the same...
Here I will even repost the think...
https://honda-tech.com/forums/showthread.php?t=2458280
Old Nov 16, 2011 | 07:17 AM
i bookmarked that whenever you first posted it up. and ive done all the above, and still no prevail.
a buddy of mine has the guts of a p28 so i was going to see if it would get my car running, and if it runs decent, then i will make a trip to a friends shop and get a b16 ecu from him
Old Nov 16, 2011 | 09:00 AM
DO IT ON ALL FOURS
Sounds like a good idea. Just wanted to be sure people understand a solid CEL doesn't necessarily mean its a bad ECU.
Old Nov 16, 2011 | 09:02 AM
i just messed with the grounds a bit more.
changed a terminal connector on my + battery cable.
the starter definately has more "punch" but it still wont crank up.
at one point i did check for CEL codes and instead of 0. i got 20. ELD code.
so at least its showing some signs of life.
gonna tinker with it a little bit more.
i accidently had it in gear and it lurched at me about 8in. so thats a good sign.
probably gonna push start it tomorrow and see
Old Nov 16, 2011 | 09:21 AM
4drEF's Avatar
Keyboard Humorist
Your car has been a grounding issue from the beginning!
If you were local I would happily stop by and replace all your grounds for free.
This thing is getting irritating!
Old Nov 16, 2011 | 10:26 AM
How do you think I feel?! Lol its soo aggravating.
I also fiugred out why when I first got the car running my ckp code came on.
Here are the grounds I have and that I cleaned up
Trans to chassis - used one of the clutch cable bracket bolts to secure it.
Valve cover to core support
Thermostat ground has been cleaned
And I have my - terminal grounded to my shock tower but I think I'm gonna move it to the trans
Old Nov 16, 2011 | 01:44 PM
DO IT ON ALL FOURS
He had his battery ground to the shock tower; the old saying is true - "You can't fix stupid."
Old Nov 16, 2011 | 01:57 PM
4drEF's Avatar
Keyboard Humorist
Think he inherited it that way?
Had a ground going to a bolt under the seat too 0_o
Old Nov 16, 2011 | 08:22 PM
HEY NOW!!!
we live and we learn from our mistakes.
im gonna hook the neg. cable to a different spot on the trans and see what that does.
Old Nov 17, 2011 | 04:38 AM
TearSDMF89dx's Avatar
hopefully it starts your car and ends this thread and the four others on this subject
Old Nov 17, 2011 | 07:22 AM
KINGVEM^^ED6's Avatar
Lulz gl op
Old Nov 17, 2011 | 08:59 AM
moved the neg. battery cable to the trans as well. and nothing
Old Nov 17, 2011 | 09:12 AM
4drEF's Avatar
Keyboard Humorist
Plug in -ANY- OBD1 ECU and turn the key to ON. (no need to try to start)
See if CEL turns off.
If CEL turns off, then your PR3 is toast.
Old Nov 17, 2011 | 04:39 PM
thanks everyone here at H-T that have helped me.
got the hatch started today and it drives damn good now.
no longer in limp mode. still throwing codes for the o2 and IACV. but thats nothing compared to the troubles i have had lately.
Old Nov 17, 2011 | 05:59 PM
crx_si-r's Avatar
so what was the problem? ecu?
Old Nov 18, 2011 | 09:12 AM
ecu wasnt getting enough power.
the battery was somehow discharging. so i put the battery on a charger, and after about 30 mins. it cranked right up.
idles fine now. and drives even better
Old Nov 18, 2011 | 10:25 AM
DO IT ON ALL FOURS
W...h...a...t...?...?...?...
Are you serious? Were these 10 different threads you started all over a battery? Funny joke I guess... you got us - just don't do it again.
Old Nov 18, 2011 | 10:46 AM
crvtectim's Avatar
Lmfao! I thought the parts store threw a good charge on it for ya... what kinda HELL???
Old May 30, 2017 | 10:19 AM
EDDIE EVANS96's Avatar
If the cel stays solid when you jump the connector could that also mean you don't have any codes or does it only mean code 0?
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
1sikhatch
Jan 31, 2010 09:06 AM
esca
Oct 14, 2004 06:34 PM
Toda Built
Jul 10, 2003 02:46 AM
TheHater
Jun 24, 2002 01:47 PM
