Can Seafoam damage the engine?!?!
Old Apr 12, 2005 | 10:37 AM
fe519's Avatar
Default Can Seafoam damage the engine?!?!
well, heres what happened... I finally got my hands on a can of seafoam yesterday and couldnt wait to put it into the car. I got home and unplugged the brake booster line and stuck it halfway down the can. I started it and it choked, smoked, etc... I let it sit for about 10 mins and when I started it, it has a valve tapping noise thats pretty loud (it wasnt there before). I drove for about 30 miles now and the tapping is still there. It ususally gets loud at about 2-4k RPM. Is there anyway seafoam can bend/damage my valves? I tried this method in my prelude and integra and no problems. Thanks for the help.
Old Apr 12, 2005 | 03:21 PM
MtnCRX's Avatar
Default Re: Can Seafoam damage the engine?!?! (fe519)
free bump because im curious
Old Apr 12, 2005 | 03:24 PM
CRXVTEC69's Avatar
wtf is SeaFoam?
Old Apr 12, 2005 | 03:26 PM
kulangot's Avatar
Default Re: Can Seafoam damage the engine?!?! (CRXVTEC69)
why did you use so much?
Old Apr 12, 2005 | 03:44 PM
MtnCRX's Avatar
Default Re: Can Seafoam damage the engine?!?! (sirq2u)
does anyone have any good detailed instructions on using seafoam? the bottle's directions are very vague and ive been reading more and more problems caused by user error.
Old Apr 12, 2005 | 04:02 PM
doublethink's Avatar
you used the WHOLE CAN?
Old Apr 12, 2005 | 04:06 PM
kulangot's Avatar
Default Re: Can Seafoam damage the engine?!?! (MtnCRX)
https://honda-tech.com/zerothread?id=1153303
big write up on seafoam.
Old Apr 12, 2005 | 05:21 PM
bagpipe goatee's Avatar
lets see, can seafoam damage
lets analyze this
seafoam is a strong detergent that dissolves oils.
therefore, when you put a little of it in, it will clear up deposits. however, on an engine ready to have problems, sometimes carbon deposits hold things together (ie headgaskets).
so, maybe your valves had a layer of carbon on the seats, and when that was dissolved, it threw your valves out of adjustment? but that would leave the valves tigher, not really causing ticking.
another thing, that seems far-fetched, but well you did use a whole lot in a short time, is that maybe it dissolved the oil off the valve guides and stuff? those don't like to run without it.
good luck.
i'd adjust your valve lash and then just drive it, if the cylinder head dies or you start burning a lot of oil, well live and learn. but you should be fine.
Old Apr 12, 2005 | 05:36 PM
ALX's Avatar
ALX
Default Re: (bagpipe goatee)
from my recollection your supposed to pour down the foam with the engine on, pour in slowly and only use 1/3 of it
the other third goes in the crank case (oil) and the rest in the gas tank.
Old Apr 12, 2005 | 07:27 PM
GSRCRXsi's Avatar
Default Re: (ALX)
from what i understand you are supposed to SLOWLY pour the sea foam into the engine. just sticking the hose in the bottle and starting the engine seems like a really dumb move. did you even read the directions?
the ticking noise could be a knock. if you sucked too much into the engine you could have done some damage due to hydrolock. in which case you would have bent a rod and not a valve. rod knocks are usually lounder then a valve tick. does the ticking/knocking increase when you increas the rpms?
Old Apr 12, 2005 | 07:35 PM
johnzm's Avatar
Default Re: (GSRCRXsi)
some dude in the allmotor section just hydrolocked his engine usig the same delivery method
if its fro the head, jusst adjusst ur valves.
coming from oil pan/bottom end, better run a comp test
Old Apr 13, 2005 | 01:26 PM
fe519's Avatar
Default Re: (johnzm)
well, the ticking increases usually at higher rpm... anything above 2k. Do you think its the rod or the valves... it kinda sounds like the valves since its not that loud. what do you think?
Old Apr 13, 2005 | 01:27 PM
underage's Avatar
the e30 bimmer guys use this stuff a lot. they suck the whole can in a vacuum line on the intake manifold while the car is running. then they shut the car off, let it sit as long as possible (up to a day, for better results), and change oil soon after using seafoam.
tegman85
Sep 27, 2006 09:51 AM
eMpAtHy
Sep 22, 2004 01:50 PM
pimpinainteasy
Aug 4, 2003 02:51 PM
bananacruzier
Feb 16, 2002 10:06 AM
vpforeva
Oct 12, 2001 05:59 PM
