brake line tuck
Old Apr 28, 2010 | 11:13 PM
88 EF Hatch's Avatar
Default brake line tuck
so I am going to pull my motor this weekend because im painting my bay, and I already have a wire tuck that i did to my 88 dx hatch with a b16. The brake line tuck looks easy, the only question i have is does the prop valve ( i have a DA valve since i have DA front brakes and rear brakes and Brake Booster and Master cylinder) have to be mounted some where specific in respect to brakes? example: does the prop valve have to be above the brake assembly? below master cylinder? or can it simply be mounted any where you would like? help would be appreciated, does any one know where i can find pics done on an ef?
Old Apr 30, 2010 | 07:31 AM
Default Re: brake line tuck
ttt
Old Apr 30, 2010 | 08:57 AM
kwell's Avatar
anywhere
Old Apr 30, 2010 | 09:14 AM
KINGVEM^^ED6's Avatar
Originally Posted by 88 EF Hatch
ttt
no need to bump threads read rules
Old Apr 30, 2010 | 09:15 AM
blasterman87's Avatar
Originally Posted by kwell
anywhere
really? such a general answer im sure it really helped him . good job
Old Apr 30, 2010 | 10:01 AM
mayfly's Avatar
it can be mounted where ever. because its a hydrolic system and it is pushed through the lines.
Old Apr 30, 2010 | 08:04 PM
beansandrice's Avatar
Yea... Super hot brake fuild lines ran inside the car sounds awesome.
Old Apr 30, 2010 | 08:39 PM
radex7's Avatar
beansandrice, don't be a drama queen, it is not helping...
OP. check one of the more recent threads by fabmaster, he is going all the way with the tuck, it seems he knows his stuff: https://honda-tech.com/forums/showth...2756264&page=1
And to answer your question - with such small change in mounting heights, and lengths of brake line sections I doubt it really matters where you move the stuff, that's what you bleed the brakes for. Well, someone can maybe prove me wrong.
Old Apr 30, 2010 | 09:51 PM
Echo 6's Avatar
In the shaved, tucked, etc. thread i have seen prop valves mounted inside the car behind the dashboard, and like Radex said, its a hydraulic system so as long as its bled properly you should be good
Old May 1, 2010 | 10:16 AM
Say what you say but I have fixed many crappy brake line tucks done by kids. There is a reason why the lines are ran outside the vehicles during manufacturing.
learn the hard way then knuckle head..
Old May 1, 2010 | 10:40 AM
radex7's Avatar
Originally Posted by beansandrice
Say what you say...
There is no doubt in my mind that when dealing with the brake lines - there is only one way of doing them - properly - but that predominantly refers to not making kinks in the line, crushing the line, or not flaring properly thus not sealing well; and that is all that comes to my mind right now. I can only hope that OP realizes that with butchered brake job - his life is at stake. Else, he will pay you, or someone like you, to fix it or to do it right.
Heck, I took everything out of my engine bay but brake lines I will not touch. For now.
Old May 5, 2010 | 10:53 PM
alright so i did not end up doing the job, left the brake lines in the bay thanks for all your help
Old May 5, 2010 | 11:51 PM
hatchet_honda's Avatar
i do believe on this 88 honda the brake lines already run inside the car...under the carpet...from the factory
braass91
18
Jul 19, 2012 11:38 AM
graham412
Mar 24, 2011 09:57 PM
88 EF Hatch
Suspension & Brakes
Apr 30, 2010 07:31 AM
92integraVTECgsr
Nov 7, 2005 09:15 PM
C2Imports
Oct 6, 2004 08:50 PM
