Help with mpfi
Old 08-08-2018, 08:11 PM
leemurrr's Avatar
Default Help with mpfi
I have a 1990 Honda Civic with a b18b1 from a 95 Integra. It has dpfi with a p75 ecu. Could some tell me where the distributor wires plug into the ecu. I've looked and everything I've found says put c1/2 into b10/12 but the p75 only has a,b,d. Any advice would be great.
Old 08-09-2018, 05:18 AM
scelestus's Avatar
Default Re: Help with mpfi
So you have a dpfi harness that you are converting to mpfi? The guides are for converting to OBD0 mpfi, but the P75 is an OBD1 ECU. You need to convert the harness as the guides indicate and get an adapter harness. Otherwise you need to replug/pin the whole ECU end of the harness to mate to the P75.
Old 08-09-2018, 06:26 AM
leemurrr's Avatar
I bought the car wired like this and the guy had it running for 3 days then he hit a pot hole and the cel came on and it went into limp mode. I'm pretty sure the wires are all hooked up right but the blue/green and blue/yellow from the round distributor plug( that were run seperate) are at the ecu but not plugged in. It looks like they popped off when he hit the pothole. All the other wiring seems correct from what I can see. I just don't know where to plug in the b/g & b/y on the p75
Old 08-09-2018, 09:03 PM
Marcos Barrios's Avatar
they dont plug to the ecu
you already have a jumper harness installed thats the only way you can have that ecu connected right now
so pay attention and youll see where that jumper harness its plugged in to the stock connections of the car
those are your obdo connections those are the a b and c plugs
the two wires that came off go to those
with me so far?
88_hatch_ls
10
07-28-2013 08:40 AM
avaldez
06-24-2009 12:59 PM
driftam1
04-25-2008 09:13 AM
tuan...
01-04-2004 08:07 PM
Quick Reply: Help with mpfi
