Honda CR-V & Element 2WD & 4WD Element & CR-V
Timing at idle?
Old Mar 5, 2016 | 11:03 AM
jeckel7234's Avatar
Default Timing at idle?
Hey all,
I just bought a Blue Driver OBDII Scan Tool and real time reader. So I just walked and scanned both of my vehicles a 2004 Accord 2.4L & 2006 CR-V 2.4L. The accord held a consistent timing advance at 6 degrees positive but the CR-V timing advance went back and forth between 1 & 9 degrees positive. I feel like this is either a wore timing chain or tensioner or both. Can someone please tell me that Im crazy and the vehicle is perfect shape and Ill have no money to spend...
Thanks,
-Drew
Old Mar 5, 2016 | 12:33 PM
UK-Kev's Avatar
Default Re: Timing at idle?
Did you check the idle RPM “warm engine” before checking ignition timing.
On the 2 litre engines over here, the ignition timing is>>> 8+/- 2 degrees BTDC
You might want to consider doing a static timing check.
Kev
Old Mar 5, 2016 | 05:26 PM
jeckel7234's Avatar
Can you explain to me what a static timing check would be.
Thanks
Old Mar 6, 2016 | 05:02 AM
MikesRJ's Avatar
Base timing is mechanical timing (distributor position) of the engine without the cars Engine Control Module (the ECM or "computer) interacting with the engine timing circuit.
Old Mar 6, 2016 | 07:02 AM
UK-Kev's Avatar
Thanks
Static timing is explained in the Haynes workshop manual; basically it’s aligning all the timing marks to make sure they are correct and not a tooth out.
Kev
beocop
Dec 15, 2016 09:05 AM
bopbop93030
Feb 24, 2009 02:57 PM
kixcrx
Nov 10, 2006 10:33 AM
kornerk12
Dec 18, 2005 03:16 PM
handa
Apr 11, 2005 10:36 AM
