Honda CR-V & Element 2WD & 4WD Element & CR-V
Scanner for Throttle Position reset
Old May 24, 2018 | 02:17 PM
elynen's Avatar
Default Scanner for Throttle Position reset
Hi,
I have a 2006 CRV (made in Japan) that I need to get a scanner for to be able to reset the throttle position. Can you help?
Old May 25, 2018 | 07:35 AM
elynen's Avatar
Default Re: Scanner for Throttle Position reset
Hello again,
Please, has anyone had to go through a throttle body cleaning and then deal with idle issue?
Thanks,
Erick
Old May 25, 2018 | 10:51 AM
UK-Kev's Avatar
Hello,
If you are talking the RAW data setting in the rheostat throttle pedal this comes factory set. However if you are having problems with the throttle sensor which I believe you are, then the attached pdf should help.
File Type: pdf
dhdave2509
Engine Management and Tuning
Feb 20, 2010 08:59 PM
Cpt Ben
Apr 5, 2007 07:18 PM
Fastwhip
Aug 19, 2006 10:35 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
