Honda CR-V & Element 2WD & 4WD Element & CR-V
Problem with blower motor
Old Dec 26, 2010 | 07:25 PM
lotz6996's Avatar
Default Problem with blower motor
The blower motor on my fiance's 97 crv only blows on high. Any suggestions on what to look for? Will check the relays tomorrow. But would like to know which ones they are, I don't have my computer that has all of the service manuals.
Old Dec 26, 2010 | 07:37 PM
redbull-1's Avatar
Default Re: Problem with blower motor
Usually when it only blows on high, it's the power transistor.
Old Dec 26, 2010 | 07:45 PM
lotz6996's Avatar
Would you happen to have the easiest way of taking that out?
Old Dec 26, 2010 | 08:08 PM
redbull-1's Avatar
Remove the glove box first (these are instructions on replacing the air cabin filter; but, they include removing glove box.
http://www.micronair.us/assets/pdfs/86.pdf
Power transistor is right behind there. Two screws hold it from the top. But, on your fiance's earlier CR-V, you may first have to remove the plastic shroud and maybe even the fan (take a look first) and then pull the power transistor out. (For newer CR-V, it is removed from the top by the two screws.
http://www.crvownersclub.com/forums/...3&d=1257183664
Old Feb 25, 2014 | 06:02 AM
luvnwater's Avatar
I replaced my transisitor on my 99 v and it worked for a day. back to high speed only.
kaylawoolley
Oct 11, 2017 03:28 AM
VTEC-LUDE
15
Sep 6, 2007 11:05 AM
idewson
Mar 4, 2007 07:34 AM
HeelToe
Jan 31, 2004 10:45 AM
bejane
Aug 8, 2002 02:09 PM
