Honda CR-V & Element 2WD & 4WD Element & CR-V
2007 CRV Instrument Panel Fail, HELP!
Old Mar 12, 2012 | 05:50 PM
Palmer Hiltom's Avatar
Default 2007 CRV Instrument Panel Fail, HELP!
Hello all,
new to this site.
My 2007 CRV (under 30K miles) 's instrument panel started to blink couple of months ago. and now it is almost black out.
I brought it new from dealer less than 5 years ago.
Now I was told to pay $$$ for the repair.
Any ideas or suggestions, please!
I could not attached the picture to this post.
So this is the link for the picture of the instrument panel.
https://skydrive.live.com/redir.aspx...GzfCqoNLpknfYs
Hope this will help. Thanks for all the information you can provide.
Old Mar 13, 2012 | 04:40 AM
c0alition's Avatar
Default Re: 2007 CRV Instrument Panel Fail, HELP!
I'm not sure how those look on the backside, but I'm thinking unless you've got a bit of electronics repair, the dealer is probably going to be the best bet - loads of money or not.
Is the screen blacking out all of the text or just half of certain characters and certain areas of the screen?
Old Mar 13, 2012 | 05:26 AM
When it's blinking, part of the screen is blinking.
But sometimes this gets worse, and the whole screen will fail.
If you could please check the picture link, you may have a better idea.
Thanks for your response.
Old Mar 13, 2012 | 06:42 AM
c0alition's Avatar
I wonder if you have a loose connection in the back? I looked at the picture earlier, and just now. It seems some of the characters are missing segments? I think that if the panel was going to fail it would be a bit more inclusive.
I've run a quick Google search and haven't seen many cars with this problem. I saw one post elsewhere that was showing your symptoms after a seat re upholstery job. Seems coincidental, but maybe there is a plug somewhere that was removed, pulled, or otherwise tampered with.
I'd check connections on the back if you're confident enough to pull the gauge cluster out. Could be as simple as unplugging the display and plugging it back in. Also maybe try an electrical reset. Pull your ground from the battery let it sit a bit and then hook it back up.
Old Mar 15, 2012 | 05:22 AM
Thank you, c0alition.
I will try that. Thanks for this helpful information.
Old Apr 13, 2012 | 07:23 PM
2000crv sport's Avatar
i have a question. have looked couldnt find an answer . i have a 2000 crv and just the odomiter doesnt work i just bought it and has 80,000 ish km's on it but hasnt moved since i bought it. im a bit worried but really just want too get it fixed. can anyone help ?
Old Aug 3, 2012 | 01:36 PM
bump
Old Feb 22, 2017 | 11:03 AM
jumpStartMe's Avatar
Sorry to dig up this dinosaur from the past, but my 2007 CR-V just had this happen, for the first time, today. I took pictures of the issue and - well - when I found this thread and looked at the picture posted by Palmer Hiltom (skydrive) ... mine looks EXACTLY like that! Like two left side doors open, "No Key" and "Batt" showing. Avg MPG and odometer is jumbled. Temp gauge is displaying it's "bar" but gas is not showing any bar. The last message posted was - you'd try checking the wires behind the cluster. I'm wondering if this worked - or - what DID eventually work? Rather than re-invent the wheel or pay for an expensive repair on such an old vehicle, I'd love to know if this was a quick/easy DIY fix? Thanks.
Old Feb 22, 2017 | 01:39 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The 2007 CR-V Information Display has a pixelation fault, it is generally not due to the wiring.
There is someone on ebay that can repair it, if you remove the entire cluster and send the unit. You can also search for other places that have experience repairing it.
Old May 16, 2017 | 07:35 AM
areben's Avatar
Hi!
I have the same problem with my 2007 Honda CR-V. Did you found out what was the problem and how much did it cost?
CoLdpLayJDM
Oct 24, 2004 07:00 AM
revvin9k
Oct 12, 2004 06:55 PM
3vilMonkey!
Jul 30, 2003 06:04 PM
