wrong engine help???????????????
Old Apr 28, 2007 | 06:36 AM
r0nr0n's Avatar
Default wrong engine help???????????????
look i bought a 97 civic didnt know it had a d16y5 in it befor i got the car home.i went an bought a d16y7 never knew i had a sohc vtec.now i have a non vtec in the damn thing the bottom end is bad on the old engine thats why i put a new one in to begin wit, can i swap the heads "like" a mini me or should i just go get the ecu i think the ecu for the engine i got was an a/t i have a m/t what should i do anyone????? just wanna get it runnin good not tryin to do any thing big right now ls turbo by end of summer so
Modified by r0nr0n at 4:13 PM 4/28/2007
Old Apr 28, 2007 | 06:39 AM
ek4h's Avatar
Default Re: wrong engine help??????????????? (r0nr0n)
mini me but if you have the money go for a LS motor i guess
Old Apr 28, 2007 | 06:45 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: wrong engine help??????????????? (ek4h)
Wow was that really all one sentence?
I've read that twice now and I'm still not any higher than 50% sure what you're talking about.
Just swapping random engine heads doesn't net you a mini-me FYI.
Old Apr 28, 2007 | 12:15 PM
r0nr0n's Avatar
can i put the y7 head on the y5? the part about the ecu if i just put the ecu in the car that goes wit the engine will that work even tho i have the y7 harness in it.
an i dont have the money to do the ls sawp or what not i just need to get this car runnin good
ps i put the a/t y5 ecu in now it wont stay runnin unless i hold the gas theres no check engine light
Old Apr 28, 2007 | 02:54 PM
r0nr0n's Avatar
ttt
Old Apr 28, 2007 | 05:54 PM
NOFX's Avatar
H-T White Ops
The D16Y5 is not a SOHC VTEC. It's a SOHC VTEC-E.
D16Y5
1.6L SOHC VTEC-E
115hp @ 6200rpm
104lb-ft @ 5400rpm
9.4:1
D16Y7
1.6L SOHC non-VTEC
106hp @ 6200rpm
103lb-ft @ 4600rpm
9.4:1
D16Y8
1.6L SOHC VTEC-II
127hp @ 6600rpm
107lb-ft @ 5500rpm
9.6:1
Old Apr 29, 2007 | 09:27 AM
r0nr0n's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">The D16Y5 is not a SOHC VTEC. It's a SOHC VTEC-E</TD></TR></TABLE>
THANKS FOR NOT ANSWERIN THE ? PEOPLE VTEC IS VTEC I PUT A DAMN NON VTEC ENGINE IN THE CAR IT HAD A "VTEC E" WHAT HOW DO I GET THE THING TO RUN RIGHT? WILL THE HEAD OFF THE Y5 FIT ON THE BLOCK OF A Y7 IS THAT SO HARD IF U HAVE A USELESS POST DONT SAY NOTHING NOT TRYIN TO BE AN *** BUT EVERYONR OF THESE FOURMS HAVE PEOPLE WHO THINK THEY KNOW WHAT THEY R TALKIN ABOUT WHEN THEY DONT SO IF U GOT AN ANSWER THAT MIGHT HELP THANKS
Old Apr 29, 2007 | 12:54 PM
NOFX's Avatar
H-T White Ops
Default Re: (r0nr0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r0nr0n &raquo;</TD></TR><TR><TD CLASS="quote">THANKS FOR NOT ANSWERIN THE ? PEOPLE VTEC IS VTEC I PUT A DAMN NON VTEC ENGINE IN THE CAR IT HAD A "VTEC E" WHAT HOW DO I GET THE THING TO RUN RIGHT? WILL THE HEAD OFF THE Y5 FIT ON THE BLOCK OF A Y7 IS THAT SO HARD IF U HAVE A USELESS POST DONT SAY NOTHING NOT TRYIN TO BE AN *** BUT EVERYONR OF THESE FOURMS HAVE PEOPLE WHO THINK THEY KNOW WHAT THEY R TALKIN ABOUT WHEN THEY DONT SO IF U GOT AN ANSWER THAT MIGHT HELP THANKS </TD></TR></TABLE>
Why don't you learn what you're talking about first.
"VTEC is VTEC" is not a true statement. All "VTEC" is not the same.
And yes, you are coming off as an ******* now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r0nr0n &raquo;</TD></TR><TR><TD CLASS="quote">look, i bought a 97 civic. i didnt know it had a d16y5 in it before i got the car home. i went an bought a d16y7. i never knew i had a sohc vtec. now i have a non vtec in the damn thing.
the bottom end is bad on the old engine. that's why i put a new one in to begin with.
can i swap the heads "like" a mini me or should i just go get the ecu. i think the ecu for the engine i got was an a/t. i have a m/t. what should i do? anyone????? i just wanna get it runnin good. i'm not tryin to do any thing big right now. ls turbo by end of summer.</TD></TR></TABLE>
I just re-read this to figure out exactly what you wanted to know again.
If you're going to do an LS turbo at the end of summer, why do anything to this motor? JUst keep it stock, run it for a few months and then go LS turbo. Don't expletive with what you have right now and just sell the Y5 head to someone who might be able to use it.
Modified by NOFX at 2:22 PM 4/29/2007
Old Apr 29, 2007 | 03:00 PM
r0nr0n's Avatar
I JUST BOUGHT THE CAR 3 DAYS AGO WHEN I BOUGHT IT IT HAD A BAD ENGINE SO I BOUGHT A JUNK YARD ENGINE THE SAME DAY DIDNT KNOW I GOT THE WRONG ONE TILL IT WAS TO LATE NOW ITS IN THE CAR AN WONT SATY RUNNIN UNLESS I HOLD THE GAS IM NOT TRYIN TO DO ANYTHING CRAZY RIGHT NOW WIT IT I JUST WANNA DRIVE IT
Old Apr 29, 2007 | 03:27 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r0nr0n &raquo;</TD></TR><TR><TD CLASS="quote">I JUST BOUGHT THE CAR 3 DAYS AGO WHEN I BOUGHT IT IT HAD A BAD ENGINE SO I BOUGHT A JUNK YARD ENGINE THE SAME DAY DIDNT KNOW I GOT THE WRONG ONE TILL IT WAS TO LATE NOW ITS IN THE CAR AN WONT SATY RUNNIN UNLESS I HOLD THE GAS IM NOT TRYIN TO DO ANYTHING CRAZY RIGHT NOW WIT IT I JUST WANNA DRIVE IT </TD></TR></TABLE>
The you should focus on getting the Y7 that's currently in the car running right. Don't worry abotu swapping heads and such.
Are you still using the Y5 ECU?
Old Apr 30, 2007 | 12:55 PM
r0nr0n's Avatar
Default Re: (NOFX)
Are you still using the Y5 ECU?</TD></TR></TABLE>
THATS WHAT IM TRYIN TO DO YEAH TILL I GET THE RIGHT ONE FOR THE Y7 THE ONE THAT CAME WIT IT WAS FOR AN AUTO TRANS I NEED THE M/T ONE I JUST FOUND THAT THE IAC WIRES ARE DIFFERENT I THINK THIS WILL FIX MY PROB,
I WAS JUST ASKIN ABOUT SWAPIN THE HEADS CAUSE I HAVE IT AN I COULD JUST DO THAT REAL FAST THEN TRYIN TO FIND THE RIGHT ECU AN HOPE ALL IS WELL
Old Apr 30, 2007 | 02:25 PM
NOFX's Avatar
H-T White Ops
Btw... stop posting in all caps.
Zeroamaze
May 23, 2019 12:59 PM
paulius907
Dec 28, 2018 01:04 PM
LandeZak
24
Jan 25, 2014 03:37 AM
EG-6SRNAC
14
May 12, 2010 11:59 PM
