will 15x7.5" or 15x8" wheels fit on an eg?
uh... yeah what he said....
looking to go 225/45/15 tires for auto-x next year but i don't think 15x7" rims will be quite wide enuff for r-comps... these would be my track only wheels/tires so i don't really think it would matter too much if they rub only at full lock- how often do you go full lock on course? unless you spin it and have to back up https://honda-tech.com/forums/images/smilies/emwink.gif my car is lowered pretty much right to the tires so i would need to stay right around a 40mm offset or greater anyone have any thoughts? |
Re: will 15x7.5" or 15x8" wheels fit on an eg? (stmotorsports)
225 is too large IMO. 205 is more than enough and has a large selection including the infamous Azenis.
Re: will 15x7.5" or 15x8" wheels fit on an eg? (Spade)
I have 17x7.5 on my civic, only slight rub at full lock, with 205/40r17 tires, with a 45 offset.
8" wide is too much, but I think you'd be able to get away with a 215 wide tire. For a 225, you'd have to raise your car and for a 8" wide rim you'd need a huge offset and maybe even a spacer. |
Re: will 15x7.5" or 15x8" wheels fit on an eg? (Marauder)
unfortunately unless some of the tire manufacturers are planning on coming out with some new sizes for next year, tire size selection of auto-x race compounds is fairly limited, pretty much either 205/50 or 225/45 would be the only width/profile I could really consider running. I've never seen a 215...
I'm running 205/55/14s on 14"x6" rims on the car now as I was competing in stock class up until I lowered it and did a bunch of other misc. stuff recently, but now that I don't have to worry about the stock wheel size requirements anymore I figured I would see if I could squeeze something a little wider on there... I dunno... ?? http://images.honda-tech.com/set1//smile/emcrook.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">I have 17x7.5 on my civic, only slight rub at full lock, with 205/40r17 tires, with a 45 offset.
8" wide is too much, but I think you'd be able to get away with a 215 wide tire. For a 225, you'd have to raise your car and for a 8" wide rim you'd need a huge offset and maybe even a spacer.</TD></TR></TABLE> i have the same size rims 17x7.5 (5zigen copse) in my EJ6 95 coupe and i dont rub at all. no spacers. i use the nitto tires if that helps. very good grip too! |
http://images.honda-tech.com/set1//smile/emcrook.gif ...do search for 15x8. This has been covered.
https://honda-tech.com/zerothread?id=525452 |
