Valve adjustment cost
Old May 8, 2005 | 08:39 AM
s2k drifter's Avatar
Default Valve adjustment cost
I got some ticking noise I would like to get rid of on my gsr. I think its time for the valves to be adjusted. I looked at a few links on "how to do", looks a little annoying. How much does this cost? Honda/acura would charge a arm and a leg probably but how about a reg. shop?
Old May 8, 2005 | 08:43 AM
jlacoy82's Avatar
71.192.16.183
Default Re: Valve adjustment cost (EK project hybrid)
Angled feeler gauge = max $5
Cheapo socket set for removing valve cover = less than $10
Flat head screwdriver = $3.00
10mm crescent wrench w/ box end = $2-3.00
Wrench/breaker bar + socket for crank pulley bolt = $20-30
Torque wrench for tappets and valve cover bolts = borrow one
$40-50 approximately, and not only do you get your valves adjusted and a little knowledge of your car, but you also get some tools in the deal!
Old May 8, 2005 | 08:49 AM
_Cyclone_'s Avatar
Default Re: Valve adjustment cost (jlacoy82)
I didn't even need to use a breaker bar to move the engine, I just used my 1/2" drive socket wrench, long *** extension, and the 17mm socket. I didn't feel like going all the way back inside to get the bar... or jacking the car up and taking the wheel off.
Old May 8, 2005 | 09:01 AM
DBLAZE's Avatar
Default Re: Valve adjustment cost (CycloneBlue_1.6EL)
**** THAT MAN...I LIVE IN NJ AND I GOT MY VALVES ADJUSTED ON MY B-16 FOR ONLY $65... ITS SO EASY, THAT IF YOU ASK AROUND YOU SHOULD GET IT DONE FOR NO MORE THAN $90. PEACE AND GOOD LUCK
Old May 8, 2005 | 09:02 AM
I have some of the basic tools but I think I would like to have someone that done valve adjustment before working on my car. It looks like teddies work and requires patience. I would watch and learn but wouldnt attempt to do this job with a "how to" guide unless I really had to.
Old May 8, 2005 | 09:04 AM
JDubbs99Civic's Avatar
you should invest some time in finding a friend who is a bad *** at hondas and have him help you for cheap.
Old May 8, 2005 | 09:07 AM
Default Re: Valve adjustment cost (JDubbs99Civic)
So far I have someone willing to work on the valves for possibly $40. Sounds good? Only problem is I might have to wait till Wednesday.
Old May 8, 2005 | 09:15 AM
_Cyclone_'s Avatar
No big deal. It's not the end of the world if you have to wait a couple of days.
Benefitx
Sep 6, 2014 06:20 AM
Powered by VTEC
16
Jan 20, 2008 03:47 PM
old_school_dohcvtec
Jun 30, 2007 06:57 PM
Hawkze_2.3
Jul 30, 2004 06:32 PM
SamC
Jan 24, 2003 08:52 AM
