problems with cel code!!!! please help
Old Apr 6, 2007 | 11:06 AM
LS AzZkIkr's Avatar
Default problems with cel code!!!! please help
i have a 92 civic vx w/ ls swap and i keep getting a o2 sensor code. i have replaced the sensor and reset the ecu by removing the proper fuses, and have also traced the wires from the ecu to the engine harness and all seem to be ok. i have also been swapping ecu's to see if one is bad. what is wrong with my car??
Old Apr 6, 2007 | 11:16 AM
amej8's Avatar
Are you sure it's even an O2 code? What's the code? Unless you used one of those readers that plug directly into a plug on your car and tells you exactly what it is.
But if you obtained the code through CEL blinks, post it up or double check it.
Old Apr 9, 2007 | 04:24 AM
LS AzZkIkr's Avatar
Default Re: (amej8)
its always a code 1. and it only happens after i drive for like 15-20 mins.
Old Apr 9, 2007 | 05:04 AM
97Ej6mike's Avatar
Make sure your using the right type of 02 sensor, because some ECU's read for 3 wire, where as some read for 4 wire. depedning on the motor
Old Apr 9, 2007 | 08:01 AM
LS AzZkIkr's Avatar
Default Re: (97Ej6mike)
i have never heard of a 3 wire o2? i have a 95 ls 5 spd ecu and a 4 wire o2 from a obd1 accord i believe.
Vvan
Dec 18, 2018 05:45 AM
95_red_dc
Sep 11, 2006 06:32 AM
notfastenough
Nov 11, 2004 04:31 PM
denshu
Jan 11, 2004 07:46 AM
blufke
Jan 9, 2003 12:15 AM
