obd2a to ob1 conversion?
Old Aug 19, 2007 | 05:45 PM
seelback's Avatar
Default obd2a to ob1 conversion?
i have a 96 hatch cx. i just put a obd2a-1 conversion harness in it with a p06 computer. with the new computer in, the motor stalls when i give it a little throttle but will rev up fine at full throttle. so i checked the code and its throwing a map sensor code. has anyone run into this problem or knows about this, if so i'd appreciate the help. thanks.
Old Aug 19, 2007 | 06:03 PM
abusedhusband's Avatar
Default Re: obd2a to ob1 conversion? (seelback)
what brand conv. harness is it.
Old Aug 19, 2007 | 08:12 PM
gamby's Avatar
Was the ecu chipped to a different program???
My hondata-socketed p28 w/ Mugen program has to be leaned out an INSANE amount at idle (with a V-AFC) in order for it to run correctly, otherwise it stalls.
This is on an OBD1-converted 99 Si.
Old Aug 22, 2007 | 02:30 PM
seelback's Avatar
it is a stock p06 ecu out of a 93 civic dx hatch w/ a five speed. and the hanress is form boomslang.
seelback's Avatar
bump
Old Aug 22, 2007 | 06:32 PM
i had a problem with boomslang harness before. i have used their product many times and one time i got a 0bd2a to 0bd1 and the v-tec pressure sensr wire was wrong, i repinned it to its corect pinand it was fine. start by check your harness. but would think that you would have a problem with your iac because the p06 sees a 2 wire and a obd2a cx sees a 3 wire
Old Aug 22, 2007 | 06:49 PM
drtysohc's Avatar
check the harness...they may have screwed up. The only thing that you should have to mess with is the IACV. search for 2 wire iacv conversion.
Old Aug 24, 2007 | 12:27 PM
seelback's Avatar
the engine harness thats in the car came out of a 98 civic ex 2dr automatic. the car didnt have any problems with old y7 computer with this engine harness, i ran into a iacv problem when i put the y8 intake on it but i fixed it. but thanx for the tips and if anyone has any other suggestions i'd appreciate it.
Old Aug 24, 2007 | 12:33 PM
seelback's Avatar
bump
1ls/vtec
May 8, 2011 09:25 AM
seelback
Sep 1, 2007 08:37 AM
slowcrxsib16
Feb 15, 2007 08:09 PM
Carbcivic
Mar 3, 2006 01:37 PM
TurblowR
May 18, 2004 09:38 PM
