Which mount is this???? ///b16a2
Old Oct 30, 2009 | 08:40 AM
EKcivicEK's Avatar
Icon2 Which mount is this???? ///b16a2
Standing at the front of the car looking in the engine bay.
on the left hand side ( passenger side ) is the trans.
you look down and on the very front of the trans there is supposed to be a mount there.
It is not the normal engine mount! its a transmission mount of some sort.
my car is missing this mount and doesnt even have the bracket.
I need to know what its called exactly so i can start looking for the correct part.
its a trannymount of some sort obviously. but what would i try to look up on ebay?
also it sucks cause i dont even have the bracket part....i have nothing.
Old Oct 30, 2009 | 08:48 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Which mount is this???? ///b16a2
??? Which year/model car?
I looked on www.hondaautomotiveparts.com to find all the engine mounts for a B16A2.
click here:
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
They are under "engine mounts" for a 99-00 Civic Si.
If you meant the bracket that bolts onto the front of the trans with 3 bolts, it's #10. If you have Polyurethane mounts, you usually don't need the torque mounts...so people eliminate them.
Old Oct 30, 2009 | 08:51 AM
EKcivicEK's Avatar
its a 96 hatch dx with a b16a2 ( si swap ) done
Old Oct 30, 2009 | 10:06 AM
98civdx's Avatar
Master Detailer
Sounds like a torque mount which you don't need
Old Oct 30, 2009 | 07:53 PM
B serious's Avatar
yep...honda put it there because you don't need it.
Old Oct 30, 2009 | 08:04 PM
gsrhatch2356's Avatar
can you B Serious.... great name and perfect for this side of HT. it is a great thing to have when you dont have solid mounts like avid or the other ones. if you do switch to solid mounts then you can delete both sides even the ac bracket if you dont run ac
Old Oct 31, 2009 | 02:59 AM
1992hondacivicvx's Avatar
is the one with the 3 holes right get it from the integra dc
Old Oct 31, 2009 | 06:07 AM
B serious's Avatar
^^I think the DC and the EM1 share that bracket. You can get it from either. IIRC, the del sol VTEC bracket will work also.
yep.
Old Nov 1, 2009 | 04:10 PM
yeah i would use it even if u have solid motor mounts
Old Nov 1, 2009 | 05:10 PM
PaulMc's Avatar
Painfully Stupid
It's missing because that car was produced with a D series motor in it. The DC and EM1 chassis share this mount because they both come stock with B series motors, which both have these "torque mounts". You don't need a torque mount on a motor that doesn't come with any torque, D series! So the chassis wouldn't have it either.
Old Nov 1, 2009 | 06:33 PM
R666_EK's Avatar
Not true. But nice try.
The bracket itself that mounts to the transmission will need to come from a B series tranny.
But the rubber mount that mounts to the chassis should be from the Civic. Si or not.
Old Nov 1, 2009 | 07:12 PM
B serious's Avatar
lol...the B16 makes like 3 more LB/ft than the D16 does. IIRC, it's 111 vs. 109 lb/ft.
The bracket itself is different between D and B series engines, but the mount is mounted on any 92-00 civic chassis.
IIRC, the EF/DA didn't have that mount. They had one in the front cross member. It's been a while since I swapped an EF....
Old Nov 1, 2009 | 10:06 PM
PaulMc's Avatar
Painfully Stupid
Are you sure? I don't remember that mount being there on my stock '97 DX hatchback..
Old Nov 1, 2009 | 10:08 PM
R666_EK's Avatar
No. If it isn't an SI, it doesn't come with it. Nice try.
How nice of you to change your reply.
Bottom line, where do you get your info bud?
My STOCK 1997 coupe had em. My friends STOCK 98 coupe HAS them. There are part listings for them... what else do you need? Yes I'm sure.
Old Nov 1, 2009 | 10:31 PM
PaulMc's Avatar
Painfully Stupid
I get my information through experience, bud.
I thought there was a possibility that I could be incorrect after you had pointed that out before.
The you said should which made me wonder if you were 100% sure or not. I wasn't about to stand behind my post 100% after you pointed it out, not looking to argue and create enemies on here like some of us.
Old Nov 1, 2009 | 10:44 PM
R666_EK's Avatar
I said "should be" meaning it needs to come from the civic chassis. Not being unsure.
I'm not trying to make enemies either. I just want to clear up misinformation as this forum seems to be plagued with it.
Old Nov 1, 2009 | 11:07 PM
uwishucould158's Avatar
its the torch mount ppl say u dont need it but i done swap and wouldnt feel safe without it that jus me i would want it there
Old Nov 2, 2009 | 04:39 AM
xXB18EKHatchXx's Avatar
Torque mount, and yes, the '97 Civic DX hatches have them also. Make sure you order the one for your Civic and not the B-series mount. I made this mistake and found out the difference when I went to install. The non-vtec civic mounts have a gap in the top where they bolt to the frame so that they fit over a ridge in the frame. The B-series vtec mounts do not have that ridge so the piece is a solid metal piece that will not bolt up without modification. Still trying to find someone with a band saw so I can cut mine and replace the destroyed ones I currently have on the car.
Old Jul 29, 2021 | 12:51 AM
Limo188's Avatar
i dont have mine and i just found out i need them one of my oem busted
the soL that could
Welding / Fabrication
Aug 21, 2011 09:12 PM
kelsodeez
Jan 9, 2010 09:33 PM
jaskuloski97sh
Jul 20, 2007 09:30 PM
TurboLaxx
19
Feb 20, 2006 11:37 PM
