1994 civic dx D15b7 ECT switch
Old 05-20-2017, 05:49 AM
tomcatter1962's Avatar
Default 1994 civic dx D15b7 ECT switch
doing a post engine installation performing a coolant bleed and my coolant fan is not coming on. upper and lower hoses are hot. jumpered the ect switch connector and the fan comes on. ran the engine to 202 degrees no fan. Is there a check you can do on the ECT switch?
Old 05-20-2017, 08:34 AM
Hysterically Calm
TomCat39's Avatar
Default Re: 1994 civic dx D15b7 ECT switch
Old 05-20-2017, 10:36 AM
Thanks Tomcat39 I will keep you posted.
Old 05-20-2017, 03:16 PM
Technical Hero
HondaPartsHero's Avatar
The ECT sensor above is the sensor that sends signal to the ECU regarding coolant temp. I believe you tested the fan switch which test would be this
Old 05-20-2017, 03:28 PM
civicservice's Avatar
Here's how to do it with basic tools (sixth gen civic):
Speardog
11
12-05-2010 02:53 PM
97civicdx
07-20-2010 05:04 AM
diyer
08-11-2004 08:34 AM
mika
08-09-2004 05:34 PM
dip-set
03-31-2004 12:06 PM
Quick Reply: 1994 civic dx D15b7 ECT switch
