how to pull check engine code from obdII?
Old Apr 4, 2003 | 11:10 AM
lsvtec101's Avatar
Default how to pull check engine code from obdII?
anyone know how to pull the check engine code? on a obdII ecu
99 civic ex
Old May 3, 2006 | 07:37 PM
hondamark35's Avatar
Default Re: how to pull check engine code from obdII? (lsvtec101)
with a code reader. turn key on, plug the thing in to the bus connector under the dash near the fuses. then follow the directions on the reader. by the way, these readers will run you about $125 and up. it's worth it to take it to a reputable shop if you don't have access to a reader.
Coolero
Oct 19, 2009 08:46 AM
baddisintegra
Dec 23, 2003 03:27 PM
racerboyb18c
Dec 12, 2002 11:15 PM
JD_B18CDX
Dec 11, 2001 12:17 PM
