Help Check engine code
Old Jun 13, 2007 | 07:28 PM
Chumbas_EG9's Avatar
Default Help Check engine code
I checked and rechecked and could not find any info regarding this.. IM sorry if i jmissed it though.
I have a check engine light, 94 civic, gsr motor(OBD1), and i cant rev above 3k.. When i go to jump for the light it just flashes the srs light.
Old Jun 13, 2007 | 08:44 PM
Default Re: Help Check engine code (Chumbas_EG9)
iv been reading.. signs point to bad ecu? but iv had this beofre and it just sttarts working again.. hmm?
Old Jun 13, 2007 | 08:54 PM
94hondacivicvtec's Avatar
https://honda-tech.com/zerothread/1901557 this is what you need
Old Jun 13, 2007 | 09:04 PM
Default Re: Help Check engine code (94hondacivicvtec)
thanks for that but i know all that.. and i dont get the CEL to flash.. the SRS light flashes instead and doesnt stop.
Old Jun 13, 2007 | 10:03 PM
so when the srs lights flashes,,and not the CEL that means a code 0? bad ecu?
Old Jun 14, 2007 | 01:03 AM
uneek360's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chumbas_EG9 &raquo;</TD></TR><TR><TD CLASS="quote">so when the srs lights flashes,,and not the CEL that means a code 0? bad ecu?</TD></TR></TABLE>
LMFAO... i have the same problem does it do the following ?
http://s161.photobucket.com/al...1.flv
Old Jun 14, 2007 | 05:17 AM
Default Re: Help Check engine code (uneek360)
kinda.. it flashes a little faster.. but while the diag jumper wire is in place.
Old May 27, 2008 | 07:22 PM
EK-4 project's Avatar
try changing out the tps sensor...
eclipsefirenos
May 18, 2009 10:11 PM
ph0shizzle
May 13, 2006 08:36 PM
Sam268
Sep 13, 2004 01:11 PM
shettysaab
May 18, 2004 12:38 PM
projecthybrid04
12
Mar 9, 2003 02:56 PM
