HELP.....13 CODE
Old Aug 30, 2021 | 07:35 AM
S Wadepca's Avatar
Default HELP.....13 CODE
Hey my Honda friends,
. I got a 93 Civic EX with a engine code 13 which is a ..... BARO - atmospheric pressure sensor.... Now What is this.....where is this located..... and how do you fix this? Hope I can get some answers....also is it drivable and yes I been driving it..🙄 Thanks!!!
Old Aug 30, 2021 | 07:45 AM
iwannarace's Avatar
Default Re: HELP.....13 CODE
Wouldn't that be the MAP sensor?
Old Aug 30, 2021 | 03:51 PM
S Wadepca's Avatar
Yes found out it is a map sensor so gonna replace that hope it fixes it. Thanks
Old Aug 30, 2021 | 09:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Code 13 is in fact a Baro Sensor Problem and NOT a MAP sensor problem, so replacing the MAP sensor will not fix your problem. The Baro sensor is found INSIDE your ECU, so you must replace the ECU to fix the issue.
Old Aug 31, 2021 | 07:01 AM
S Wadepca's Avatar
Is that the whole computer system??
Old Aug 31, 2021 | 07:03 AM
S Wadepca's Avatar
Also what does that effect as far as driving it...Thanks
Old Aug 31, 2021 | 07:05 AM
S Wadepca's Avatar
Hey I checked the codes again besides 13 code I also got a 3 code which is MAP sensor?? Oh god I don't know what to do.
Siwakan Ketwong
Honda Civic (2016 - Current)
Nov 15, 2020 10:06 PM
Luis Lopez
Engine Management and Tuning
Jul 7, 2018 07:56 PM
civicx
Oct 4, 2005 03:12 PM
smkngsr
Oct 22, 2001 08:05 PM
