96-00 coilovers on a 92-95?
Re: 96-00 coilovers on a 92-95?
You will need to modify the rear shock mount bushings!!! On 92-95, they are wider. it's not a simple bolt on thing.
Also, for the front you wil have to zip tie the brake lines to the shocks, as there wont be a mount for them.
how will i need to modify my rear shock bushing? ive heard of a "washer trick"? what exactly does that mean or is that not even relivant?
Seagull Management
You have to grind a bit off each side of the shock bushing in the lower control arm, Some manufacturers (Tokico is one) make their shocks for an EG and send spacers with them so they can be used on an EK)
nine78guy
01-31-2007 05:26 PM
loc0ej1
12-19-2004 09:50 PM
TurboBumblBee
03-29-2003 10:19 AM
