jdm B16a vs. U.S. B16
Old 02-04-2010, 07:34 PM
delsoldreams's Avatar
Default jdm B16a vs. U.S. B16
flame me if you must but I could not find what I needed with the search feature..
I want to do some maint on my 92 jdm eg2 before I take her out to Vegas in April. It is the original motor..B16a OBD0. I have a leaky vtec solenoid gasket. My problem is that I have no parts numbers list for my jdm car and was wondering if I could order the gasket and spark plug wires for a U.S. model sol? Are these two parts the same? Ive had a few U.S. model dohc sols and I think they had the B16A3.
Also, I read where when I order my oem exedy clutch replacement, that I need to order the one for a 92-93 Integra part # 08028 because of the splines. Is this information correct? thanks
Old 02-04-2010, 07:41 PM
forcefedferio's Avatar
Default Re: jdm B16a vs. U.S. B16
I want to do some maint on my 92 jdm eg2 before I take her out to Vegas in April. I have a leaky vtec solenoid gasket. My problem is that I have no parts numbers list for my jdm car and was wondering if I could order the gasket and spark plug wires for a U.S. model sol? Are these two parts the same? Ive had a few U.S. model dohc sols and I think they had the B16A3.
The VTEC solenoid gasket should be the same, the only difference you run into now and again is no VTEC pressure switch on some JDM motors.
As for your clutch it should be a replacement for a 94-97 del sol VTEC model with the b16a3 (99-00 civic Si and 94-01 integra would work too but lets keep it simple)
Old 02-04-2010, 07:52 PM
Can I also order spark plug wires for a B16A3 and use those on my B16a?
Old 02-04-2010, 08:00 PM
yes sir.
tavo.760
14
11-19-2013 10:50 PM
stegs
04-14-2009 08:12 AM
wood 1
08-31-2007 01:29 PM
omg_miiiike
04-27-2005 03:34 PM
Reelizmpro
11-28-2004 10:43 PM
Quick Reply: jdm B16a vs. U.S. B16
