Error code 41
Old Jul 31, 2008 | 04:12 AM
kuks24's Avatar
Default Error code 41
Does anyone know where I could find a list of error codes for a 1997 honda civic LX. I looked at the code and it gave me a 41 error code. Does anyond know what that code is. Thanks
Old Jul 31, 2008 | 04:18 AM
kuks24's Avatar
Default Re: Error code 41 (kuks24)
I think I just found out it is a primary oxygen sensor heater. Does that mean I need a new O2 sensor or is there something else I can do. Thanks
Old Jul 31, 2008 | 01:21 PM
blk92_d16's Avatar
Yes, the primary heating element isn't functioning thus throwing the error code. You can either ignore it like I have for the past 2 years or just get a new one.
Old Oct 23, 2008 | 11:17 PM
gamakichi77's Avatar
Default Re: (blk92_d16)
i'm throwing error code #1..is it the same with #41, i.e Bad O2 sensor?
Old Oct 23, 2008 | 11:42 PM
iamthefollower's Avatar
Default Re: (gamakichi77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamakichi77 &raquo;</TD></TR><TR><TD CLASS="quote">i'm throwing error code #1..is it the same with #41, i.e Bad O2 sensor?</TD></TR></TABLE>
The code list here says that
#1 is Oxygen Sensor "A" (Primary)
defective circuit or unplugged/defective sensor
#41 is Primary Oxygen Sensor - Heater
Circuit Malfunction
From Obd1 List
I think you could get a new one for either one and fix it ... Someone correct me if i'm wrong on this one
Old Oct 24, 2008 | 12:10 AM
Default Re: (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">
Circuit Malfunction
From Obd1 List
ermm...which one?...shall ichange my O2 sensor?
Old Oct 24, 2008 | 06:15 AM
B16aCRXSi's Avatar
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Old Oct 24, 2008 | 06:37 AM
MadScientistMatt's Avatar
It means the part of the O2 sensor that helps heat it up faster isn't working. A fairly minor nuisance; the rest of the sensor usually works. There are a couple checks Honda has to pinpoint what is wrong but it's usually the sensor.
Old Nov 9, 2008 | 04:46 AM
Charlie Moua's Avatar
Default Re: (MadScientistMatt)
<FONT COLOR="blue">
Just a few more questions:
1) will this affect fuel economy ?
2) will this affect vtec
3) if I am getting this code, it means my wiring is okay, clip to o2 sensor is fine, BUT just that the internal o2 heater senor is not working correct?
4) which other o2 sensor will work? obd-0 or ob-1 ---------------------or does it have to be ob-2?
Thanks
Charlie Moua
</FONT>
Old Nov 9, 2008 | 06:27 AM
wrenchez81's Avatar
Default Re: (Charlie Moua)
first of all that code your getting #41 is an ob1 or obd2 code.? 97 should be 2 .. anyway as posted it is the snsr 1 heater circuit.. what this means is that the o2 sensor will take longer to warm up , leaving you in open loop longer which WILL effect fuel economy... will not hurt vtec tho... code 1 is for the oxygen sensor however dot comma for signal fault ...obd 1 sensors have 1 wire and you have 4!!! and henceforth you need to use the proper sensor!!!
Modified by wrenchez81 at 7:33 AM 11/9/2008
Old Jun 24, 2019 | 12:02 AM
behp345's Avatar
Default Re: (gamakichi77) code 41
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
67 Cat Converter
80 EGR Valve/Line
hey my Honda CR-V has the error code flagging up BUT I also have a baffle in my cat could that be showing faulty o2 sensor or will it also be a fault with the sensor TIA
Old Jun 24, 2019 | 04:59 AM
mk378's Avatar
This section of the site is about 1992-2000 Civics. Take your CR-V questions to the appropriate place.
Keeper1343
Oct 25, 2007 01:56 PM
IASI2010
Jul 31, 2007 01:46 PM
YaMaJeSty
Jul 26, 2002 04:01 AM
