Engine Start Problem
Old Apr 12, 2004 | 02:21 PM
hondadelsol.co.uk's Avatar
Default Engine Start Problem
Hi, I hope that somebody can help me. I own a honda delsol (jmd Import) 1.6 vtec with the B16a engine see http://www.hondadelsol.co.uk for full details.
The engine has not been modified apart from a k+n filter
The car has covered about 85k and is in very good mechanical condition, how-ever there is a slight problem while the car warms up.
The car will start perfectly when cold but if i drive for 5 minutes and then stop and restart the engine it fires up and then instantly dies, i have to leave it for 3 to 4 minutes then try to restart it. this problem dis-appears once the car has fully warmed-up. i have changed the fuel filter (service) and also the theromstat.
If you have any ideas which may help please reply
ALSO - the central locking on the passenger door does not unlock the door but it does lock this door when operated from the drivers door
Old Apr 12, 2004 | 02:22 PM
JDMlyfestyle's Avatar
Hmm that is weird are you throwing any codes at all?
Old Apr 12, 2004 | 02:25 PM
Default Re: (JDMlifestyle)
ive not checked the ecu codes but i have just checked the link on your message and will check them tomorrow. ill post the results tomorrow
Old Apr 13, 2004 | 05:55 AM
Default Re: (hondadelsol.co.uk)
hi there, ive just checked my ecu for the fault codes by linking the 2 cables as explained but the engine check light worked as normal (lit for a few seconds then turned off)
I take from this that the ecu has nothing to report? is that correct.
then on further examination i found that the ecu was a spoon sports ecu. after browsing a few pages on the web i found that this was a replacement unit. do you know how to show the fault codes with this unit (if it is a different process) or where i could get this information???
Old Apr 13, 2004 | 06:58 AM
EK45VTi's Avatar
Try replacing spark plugs (buy those that Honda advises)... it has to be NGK or DENSO
I think they might be NGK BKR6E-N-11 but not sure... check in your car manual and buy those sparks and you will see if anything will change...
Wiretaju
Jun 24, 2010 08:31 PM
integra_si-vtec
Jul 5, 2007 11:22 AM
phils2k
Honda S2000
Sep 30, 2004 05:33 PM
2000Accord5sp
Jan 21, 2003 12:20 PM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
