Engine Problem!!?? HELP!
Old Feb 7, 2004 | 09:18 PM
davken1102's Avatar
Default Engine Problem!!?? HELP!
my hatch isnt running right, it will run good for a while and then outta i'll try to go and it will like die out like it cant go, in nutral i'll give it gas and it will just die out like it doesnt wanna run. what the hell???
Old Feb 7, 2004 | 09:32 PM
zensoku207's Avatar
any other symptoms? overheating? any recent changes to the engine? kind of vague bruh
Old Feb 7, 2004 | 09:44 PM
davken1102's Avatar
Default Re: (zensoku207)
i havent done anything to the engine, no overheating or anything. ill be driving and then outta nowhere it will just feel like it wants to die, when i start to get on the gas or floor it is just dies out. and wont go. i tryed puttin it in nutral and it still doesnt rev up it just dies out whenever i touch the gas. it barely even idles. idk how else to describe it
Old Feb 8, 2004 | 12:40 AM
zensoku207's Avatar
whens the last time u changed plugs wires cap rotor? if you floor it and no ignition occurs could be flooding problem, ??? dirty air filter??
Old Feb 9, 2004 | 07:08 AM
saleensolution's Avatar
sounds like maybe a map sensor is unpluged or stopped up try checkin that
Old Feb 9, 2004 | 07:28 AM
gezer's Avatar
Default Re: (saleensolution)
could be alot of things if you think about it, just take it to a shop and have it looked at. doesnt sound like u know much about motors, the last thing u want is to *** it up more. (or just get a new swap)
Old Feb 9, 2004 | 02:58 PM
zensoku207's Avatar
could be TPS too......
Old Feb 9, 2004 | 06:27 PM
davken1102's Avatar
i dont know much about honda's, i had a toyota and i knew ever inch but im new to honda motors. TPS's and knock sonsors and such. when i unplug the TPS it runs alittle better but the only time it dies out, like it has been, is at night. map sensor is plugged in, but i am gettin a CEL for o2 sensor and Knock sensor now, i am goin to rewire both bc they look kinda getto. do knock sensors just go out? is there a way to test if a knock sensor/ o2 sensor is good or bad?
truevietluv636
12
Apr 29, 2009 08:53 PM
downpiped
Jul 6, 2006 07:07 PM
Hcivic88
Jun 30, 2005 03:53 PM
wstef
Oct 20, 2004 01:30 AM
Subzonic
Jun 23, 2003 08:16 AM
