2000 civic si rear camber question
Old 12-02-2011, 08:15 PM
Nateborko's Avatar
Default 2000 civic si rear camber question
I was installing a new skunk 2 pro series camber kit on the front and rear. on the rear, the old bolt head snapped off holding the camber arm to the frame. how should i get this out? thanks
Old 12-02-2011, 08:21 PM
Master Detailer
98civdx's Avatar
Default Re: 2000 civic si rear camber question
A few options.
Cut threw each side of the UCA, and pull the arm out, break the welded nut off, and try to pound the little peices left behind.
Get new bolt/nut. You can weld it back on if you please.
get a new trailing arm.
Break the welded nut off, and attempt to pound the bolt threw the bushings. Thus saving it for future use/sale.
Oh, and be thankful the welded nut inside the frame didn't break. Put antiseize on all of those bolts, now!
Old 12-03-2011, 02:09 AM
Nateborko's Avatar
Okay I'm going to work on it now, thanks!
endwell17
10-05-2013 07:13 PM
TekBuDDy
03-24-2010 03:10 AM
huge230
11-26-2006 09:47 AM
Quick Reply: 2000 civic si rear camber question
