Y8 camshaft in Z6 ???
Old 09-22-2004, 12:53 AM
Evolution-93-Ex's Avatar
Location: Your mommas bed, that might be true too ..., So Cali, USA
Default Y8 camshaft in Z6 ???
I heard if you put a d16y8 camshaft into a d16z6 you will gain 2 hp is this true ??? LOL 2 hp
Old 09-22-2004, 03:15 AM
murmur9's Avatar
Default Re: Y8 camshaft in Z6 ??? (Evolution-93-Ex)
why would it matter....what do you want 2hp for. just throw boost....then you can choose how much hp you gain....till your motor blows from too much psi
Old 09-22-2004, 04:46 AM
hondainspired's Avatar
Default Re: Y8 camshaft in Z6 ??? (murmur9)
yea... prob. not worth it...
Old 09-22-2004, 10:22 AM
i wanna is this possible, i didnt ask about boost, 2 hp woop dee but its still 2 hp
Old 09-22-2004, 10:49 AM
mengy007's Avatar
I was wondering if i could put a jdm d15b camshaft into my y8 head on my mini-me
with port polish head would it gain any? from what i hear the d15b vtec cam is better then z6 and y8
Old 10-03-2004, 01:23 AM
Default Re: Y8 camshaft in Z6 ??? (mengy007)
i forgot about this but i still havent gotten a definite answer
Old 10-03-2004, 01:59 AM
Calvinator's Avatar
Are z6, y8, and d15b camshafts interchangable?
Old 10-03-2004, 04:15 AM
Default Re: (xtremeazian)
i don't know thats why i'm askin but no luck so far
Old 10-03-2004, 04:57 AM
VvPeachyvV's Avatar
should be. aren't all deseries parts interchangable?
Old 10-03-2004, 05:47 AM
slambedcivic's Avatar
Default Re: (VvPeachyvV)
92-00 i believe they are.
Old 10-03-2004, 07:20 AM
FMIDRC Racer's Avatar
Default Re: (slambedcivic)
you can put it in there but it will suck ***. i had a mini me with a z6 head and a cam gesar and had it all adjusted properly. i heard the same thing that a y8 cam gear is a good cam swap for the z6 head. well to start the y8 cam has was ground on what appears to a 1.5 index. so after i installed and adjusted all the valves i had to correct the cam timing again and then reset the ignition timing. got everything going like it should be and took it for a ride around around the block. the cra made no power under vtec and evem when vtec cam on it stilll sucked ***. i turned right back around and went back to the shop and pulled it out. i fuigured it was a problem something like this....... the y8 has a btter lift and duration cam on paper. but the y8 head is a different height, the rocker arms have a different ratio etc. so the cam lobes must really affect when the valves open. so i guess that it was opening them out of time even though the cam gear and igntion timing was all set properly.
all in all it's a huge waste of your time, don't do it.
Old 10-03-2004, 01:07 PM
Default Re: (FMIDRC Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMIDRC Racer &raquo;</TD></TR><TR><TD CLASS="quote">you can put it in there but it will suck ***. i had a mini me with a z6 head and a cam gesar and had it all adjusted properly. i heard the same thing that a y8 cam gear is a good cam swap for the z6 head. well to start the y8 cam has was ground on what appears to a 1.5 index. so after i installed and adjusted all the valves i had to correct the cam timing again and then reset the ignition timing. got everything going like it should be and took it for a ride around around the block. the cra made no power under vtec and evem when vtec cam on it stilll sucked ***. i turned right back around and went back to the shop and pulled it out. i fuigured it was a problem something like this....... the y8 has a btter lift and duration cam on paper. but the y8 head is a different height, the rocker arms have a different ratio etc. so the cam lobes must really affect when the valves open. so i guess that it was opening them out of time even though the cam gear and igntion timing was all set properly.
all in all it's a huge waste of your time, don't do it. </TD></TR></TABLE>
THANK YOU MAYN !!!!!! BOUT TIME I GOT A REAL ANSWER
Old 10-03-2004, 01:10 PM
ABK
ABK's Avatar
Default Re: (Evolution-93-Ex)
I read somewhere that you can (search it's there I know for sure), but you need to skip one tooth, don't know which way though.
Old 10-03-2004, 01:31 PM
Br1anPham's Avatar
Default Re: (ABK)
timing on y8 = more adanved then z6. (5 degrees). you might gain some high end, lose some at low end.
Skadaloz
06-02-2009 06:14 PM
The Internet Tough Guy
04-17-2006 12:01 PM
TehMoonRulz
05-30-2005 08:51 AM
tai93si
01-16-2004 07:36 AM
Quick Reply: Y8 camshaft in Z6 ???
