driverside door wont open
Old May 6, 2009 | 05:16 PM
same ol' civic's Avatar
From: really it doesnt rain as much as you think, WA, us
Default driverside door wont open
so heres the deal. i got in my car, went to the store, and when i went to get out door wouldn't open. made sure it was unlocked and rolled the window down to try from the outside. nothing. when i hit the power lock switch the little **** pops up and everything but i'm not getting anything from the handles, inside or out. thought about removing door panel but no room. anyone ran into this before or know how to get door open? much appreciated
Old May 6, 2009 | 05:21 PM
trustdestruction's Avatar
Default Re: driverside door wont open
you might have to sacrifice the door card and cut it out to get inside the door if it's as bad as i think it is.
I wanted to pull a door wire harness off a del Sol at the junkyard but the door was jammed like you described and both handles were gone. The lock mechanism was frozen (not cold, but rock hard) and we had to torch the hinges and lock striker.
Old May 6, 2009 | 05:44 PM
not the answer i wanted to hear... lol
anybody else?
Old May 6, 2009 | 05:48 PM
well i wasn't trying to say you'll have to torch it. might have to sacrifice the panel though so you can get inside the door and play with the mechanism.
Old May 6, 2009 | 06:06 PM
louie1086's Avatar
if the door wont open from both the inside or the inside, i would think that the linkages are either broken or loose. you would have to some how take off the door panel to determine which link is the problem. unfortunately, there is no way to remove the door panel with the door closed.
i would play around with your locks and make sure that they are working. also, play around with the handles to see which one is the problem.
RealRaw
Sep 2, 2020 05:22 PM
marcelosm
10
Jul 28, 2014 05:45 PM
nateb22
May 6, 2009 11:00 PM
suhteevin
Jan 6, 2009 09:04 PM
BB4
Aug 18, 2005 03:39 PM
