ECU change
Old 04-14-2011, 09:00 AM
randomhe12o's Avatar
Default ECU change
i got the P06 ecu chipped for a P29 basemap... i was just curious as to how long i need to drive it before the ECU connects with everything?
Old 04-14-2011, 09:04 AM
The Grumpiest
grumblemarc's Avatar
Default Re: ECU change
? Why? The ECU starts working as soon as you start the car.
Old 04-14-2011, 10:07 AM
hmm... i only ask because like... it was running real shitty, then when i changed it it got a little better... but i didnt know if the sensors were still in tune with the other ECU or what...
it's still iding around 1500, and when im driving and push the clutch in... it sounds like the cars about to die, and then catches around 1000 RPMS and shoots back up to 1500...
Old 04-14-2011, 10:09 AM
but then again... there was gas in the Oil, and the plugs are probably bad... it feels like it's missing... could that be it?... probably this weekend im going to do my 3rd tune up and run some sea foam... heres to hoping it fixes it.
Old 04-14-2011, 11:10 AM
turbodcxbro's Avatar
Who did the base map? is the car in good state of tune? (plugs, wires, timing, dist. cap and rotor)
What motor is in your car? what car are we talking about here? Need details...
Anyway, the ECU doesn't really need to "learn" in these things. It might learn some fuel trims but thats about it.
Old 04-14-2011, 11:27 AM
ahh.... it's a 92 civic hatch dx... with a ZC swap... Dohc, the plugs probably look like ****, and it's got MSD wires, im not to sure about the timing or the dist. cap or rotor... i dont know how to tell if it's bad or not.
Old 04-14-2011, 03:46 PM
TwoFaced's Avatar
Get OEM wires, NGK plugs, a new dist...and then come back to us...these should be swapped any time you do a swap anyways. OEM wires outperform almost every aftermarket to include ngk and msd wires. Good luck.
Old 04-14-2011, 03:57 PM
The Grumpiest
Old 04-15-2011, 03:36 PM
Default a few probs still
i thought the P06 chipped for base map p29 would fix it...
but it does seem like it's running better... but like... it's still idles around 2000/1500... and then when im driving its missing bad... and black smoke coming out when it backfires, it lacks power still when i give it a little throttle... i cleaned the IAC already.... any other suggestions to what the problem might be?
and does anyone know the firing order for the DOHC ZC?
Old 04-15-2011, 04:37 PM
The Grumpiest
Default Re: a few probs still
Why'd you start another thread?
https://honda-tech.com/forums/showthread.php?t=2923392
Sounds like you have mechanical issues.
Old 04-15-2011, 04:58 PM
vartok's Avatar
^this
Also, wouldnt hurt to check the mechanical (as in the timing the timing belt controls) and spark timing (checked with timing light)
Old 04-15-2011, 05:43 PM
Former User's Avatar
Related threads merged.
Old 04-15-2011, 05:51 PM
Seagull Management
94EG8's Avatar
Probably not, I've run a DOHC ZC on a stock P06 before and it actually ran quite well.
Old 04-15-2011, 06:55 PM
MoreCowbell's Avatar
The chip you are using is not meant for the ride which is why you are having the issues. The ecu is programmed for a certain engine and will not adjust automatically to another d-series
Old 04-15-2011, 08:14 PM
TwoFaced's Avatar
^ is that username for real?
Seriously...if you replace to obvious...you'll save yourself alot of troubleshooting. THEN look at the more expensive issues that MIGHT be a problem later. You NEED to replace plugs dist...probably water pump timing belt etc anyways...and should replace wires...so go with that then figure it out from there.
erikiksaz1
Engine Management and Tuning
06-11-2010 02:39 PM
nick91civicsi
10-25-2009 03:27 PM
§95HATCH§
05-16-2009 07:19 PM
lsjon
05-30-2008 08:41 AM
GreenGSR
12-02-2002 09:03 PM
Quick Reply: ECU change
