code 41
Old Jun 9, 2007 | 08:30 PM
commotion's Avatar
Default code 41
ok ok my first setuo was a d16z6 in my 95 ej1 with a g15 turbo kit... i keep pulling code 41.
i have since blew that motor and replaced it with a d15b which im still pulling code 41, i changed my O2 sensor 3 times.. with brand new ones .. and still pulling this code.. what could be wrong
Old Jun 9, 2007 | 09:16 PM
97Ej6mike's Avatar
Make sure you have reset the ECU as well, CEL's like that dont clear up right away, so make sure you unplug the ECU for a short period of time.
Old Jun 9, 2007 | 11:48 PM
503_EF9's Avatar
Default Re: (97Ej6mike)
also if your not aware theyre is 2 o2 sensors. good luck
Old Jun 10, 2007 | 06:08 AM
commotion's Avatar
Default Re: (dylan_surrender)
i only have 1 o2 also these codes have been cleared many of times
Old Jun 10, 2007 | 10:39 AM
503_EF9's Avatar
Default Re: (commotion)
oh. is the problem that your o2 sensor keeps going out. or is it that you keep getting the code.
Old Jun 10, 2007 | 12:03 PM
commotion's Avatar
i have had 3 o2's in there 1 when i got the car
got code 41 so i replaced it
didnt help
one when i put the new motor in.i replaced it again and still throwing this code...
Old Jun 10, 2007 | 12:04 PM
commotion's Avatar
Default Re: code 41 (commotion)
my cpu is chipped and im pulling this code with and without the chip in and i use another non chiped p28 andstill same thing all this after resetting the cpu each time
Old Jun 10, 2007 | 05:45 PM
503_EF9's Avatar
well the o2 sensor obviously isnt your problem. it has to be faulty wiring somewhere.
Old Jun 11, 2007 | 02:32 AM
commotion's Avatar
Default Re: code 41 (dylan_surrender)
im going to trace the wires back today or tommarrow
Thanks\
ill let you know what i find.
Old Jun 11, 2007 | 02:44 PM
503_EF9's Avatar
good deal.
Old Jun 11, 2007 | 03:38 PM
92sihbk's Avatar
my car was getting this too, never could figure it out, and made it run very rich. I just "hid" the problem in crome when i had my buddy chip it and it sent away the code 41 and 43 which i also had too which is fuel supply delivery or something like that.
popester1120
May 3, 2008 11:02 AM
GruvyTune
Nov 4, 2003 07:42 PM
