CEL NO CODE
Old Mar 29, 2024 | 02:53 PM
Eghatch176's Avatar
Default CEL NO CODE
Hello all, I'm working on a 94 Civic hatchback. I have a CEL on but no code, issue is intermittent and once it clears car runs good. If I check for code when light is off computer stats no issue. Once cel turns on runs terrible and very rough idle. If I jump service connector returns no code. Car is OBD1 running D16y8 tune up just done 3 months ago. I'm suspecting ICM is failing. ECU is chipped and if I create an CEL code would be given to me so I suspect ECU is running properly. Any help would be greatly appreciated, thanks.
Old Mar 31, 2024 | 03:07 PM
Eghatch176's Avatar
Default Re: CEL NO CODE
BUMP
Old Apr 5, 2024 | 12:36 PM
Eghatch176's Avatar
Replaced ICM and ignition coil and still same issue. Car has fluctuating idle and won't rev pass 4000 rpm on highway. If forced backfires. Any help?
Old Apr 5, 2024 | 01:37 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Are you jumping the service connector and then turning key to ON?
Old Apr 5, 2024 | 02:05 PM
Eghatch176's Avatar
Yes, I have checked the code and nothing given back.
zero708970
24
Jan 25, 2010 09:08 AM
Gixxerboy02
Apr 30, 2006 01:16 PM
esca
Oct 14, 2004 06:34 PM
