CEL codes 1, 9, and 22 -----> Possible effects?
My H22A EG (running a P28) is throwing the following CEL's...
1 ---> O2A - Oxygen sensor #1 9 ---> CYP - cylinder sensor 22 ---> VTEC pressure valve ...and I've been having the following problems... https://honda-tech.com/zerothread?id=1406343 Could those codes be what is wrong? PLEASE HELP! |
Re: CEL codes 1, 9, and 22 -----> Possible effects? (JDM H23A)
HELP...because I don't know what's going on! Anyone from IL?
Someone has got to know!?
...looks like I'm SOL https://honda-tech.com/forums/images...es/emdgust.gif
why dont you fix these sensors/ make sure there connected. make sure all your connections are good from the sensor all the way back to your ecu.
plus are you running an h22 on a stock p28? If so i dont eve know if i want to help you. and I thought you had an h23? your problems there can also be vaccuum but fix the sensors and get a real computer for your h22. |
Re: CEL codes 1, 9, and 22 -----> Possible effects? (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon »</TD></TR><TR><TD CLASS="quote">why dont you fix these sensors/ make sure there connected. make sure all your connections are good from the sensor all the way back to your ecu.
plus are you running an h22 on a stock p28? If so i dont eve know if i want to help you. and I thought you had an h23? your problems there can also be vaccuum but fix the sensors and get a real computer for your h22.</TD></TR></TABLE> The engine I have is the JDM H23A DOHC VTEC (blue top). I'm running a P28 ECU chipped with H22A maps and a VAFC II. By the way, what the expletive is 9 ---> CYP - cylinder sensor all about? I don't even know what that is! Could that be why it's having trouble starting (it has trouble, but it always ends up starting...always). |
what dizzy are you running and what harness.
the cyp is in the dizzy for 92-95 and on the oil pump for 96+ so i am guess you dont have it hooked up? its a cylinder sensore or crank angle something like that. does the h23a have a vtec pressure valve on the motor? and hook up your o2 sensor. is that better? |
