B20 in an ej
Ok hey i have a rolling chasis a 1994 civic dx. Im going to put in a b20 in and I want like a complete list of the parts i need and what i need to do to make this work. I know this an obd1 car and the motor is od2, so if any help or anyone can point me in the right direction it would be great.
well.....
for starters the b20 block
-b series tranny with mounts (b16,ls, gsr, itr) since the b20 is too big.
-94-00 half shaft for b series
- hydro clutch (if you don't have one)
- manual starter
- tegra axles
- 94-00 teggy shift linkage
-inspection plate
-obd 1 ecu
btw.. the harness will plug directly into your obd1 chassis harness (for the most part)
uhm...................
can't think of anything else right now.
- manual starter
- tegra axles
-inspection plate
-obd 1 ecu
OP, the proper plug-n-play solution, assuming that you are using the stock '94 Civic engine harness, would be a '94-95 Integra LS distributor.
Nameless RB26
14
Jul 29, 2009 06:10 PM
