Wiper Wont Park 96 civic. (where is the Wiper relay)
Old 01-10-2019, 02:49 AM
Tie Ee Fei's Avatar
Default Wiper Wont Park 96 civic. (where is the Wiper relay)
It just wont park. and it just stop at the same spot when i turn of wiper.. (sometimes is quite annyoing when it stop at the middle and block my vision)
and the intermittent mode not working as well. low speed and highspeed are okay, 1stly i guessing is because faulty motors but i do get a set of wiper-motor assembly from junkyard replace and still same.. so now my best bet is the Wiper relay. i do search around google, and took a search at forum but see nothing about honda civic wiper relay.
anyone can help me pinpoint where is the wiper relay ?
thanks :D
Old 01-10-2019, 03:06 AM
O.G. triple O.G.
NVturbo's Avatar
Default Re: Wiper Wont Park 96 civic. (where is the Wiper relay)
wiper relay is integrated into the under-dash fuse box. Have you tried to replace the wiper stalk?? Those will go out before the relay, in most cases.
Old 01-10-2019, 04:05 AM
Fish Twig
tony_2018's Avatar
reseat blades, try again? Also pull the cowl up and see if the bushings are toast.
Old 01-10-2019, 04:41 AM
Tie Ee Fei's Avatar
Does wiper stalk will cause not parking symptoms ?
​​​​​​The Bushing are not in perfect shape.. But i do test without blades.. It will not part either.. Cause it just stop anytime wherever i stop the wiper..
Old 01-10-2019, 04:56 AM
mk378's Avatar
Yes the switch is also involved. In the "off" position it has a contact to keep the motor running until the park position switch in the motor opens.
Tracing the circuit through a schematic and doing some ohm tests will certainly find the problem.
Old 01-10-2019, 05:07 AM
Tie Ee Fei's Avatar
Oh my gosh.. I kinda dumb in electronic . I will give it a try too . Thanks
Old 01-10-2019, 06:39 AM
chrysler kid's Avatar
It's the wiper regulator which is part of the motor. You will need to replace the wiper motor
Old 01-10-2019, 02:00 PM
Tie Ee Fei's Avatar
I replace fullset of the assembly ..
Old 01-10-2019, 11:23 PM
No you replaced with junkyard piece. Did you test the piece before you installed them?
Old 01-10-2019, 11:47 PM
Tie Ee Fei's Avatar
i was order online... at my area is not easy to find civic half cut ....
Old 01-11-2019, 09:34 AM
https://honda-tech.com/forums/honda-...-ways-2998577/
https://honda-tech.com/forums/honda-...-park-2709656/
Julles41
Honda Civic (2006 - 2015)
03-20-2013 08:21 PM
Juniorhatch
Acura TL, RL & ZDX
04-21-2010 06:58 PM
brose
11-30-2007 08:12 PM
gliaw
10-12-2003 04:53 PM
Nameless RB26
07-29-2003 03:46 PM
Quick Reply: Wiper Wont Park 96 civic. (where is the Wiper relay)
