Acceleration problem on the 96 Civic EX Auto
What else should I be looking at besides the cap, rotor, and wires?
edit: which spark plug wire would be better? Denso or NGK? NGK is $56. Denso is $37.
Ok.. my problem seems to happen when the car isn't moving also.
This video is recorded when the car is in parked gear. I had my foot steady, didn't let it go, but the RPM still goes up and down by itself.
@4.5k rpm, dropping up and down. My foot is steady, didn't let it go or push it. The car did it on it's own.
@3k rpm, dropping up and down. Same as the 4.5k rpm, foot steady.
The TPS sensor attached to the throttle body has three wires, two of which are Red/Blk and Grn/Blk. Near the sensor, scrape away a very small amount of insulation to expose the wires -- just enough to make contact with the probes of a digital multimeter. Turn the key to ON(II) and measure voltage between these two wires with the throttle closed versus wide open. Do you measure about 0.5V or 4.5V, respectively, at these two throttle positions? Are the voltages steady and do they steadily increase as the throttle slowly moves from closed to wide open?
Use a Dremel tool to score a groove into the head of the screws holding the TPS to the throttle body. Then use a screwdriver to remove the screws.
Did you test the TPS output voltages to know whether or not it is bad? You will need to measure voltages to calibrate the new sensor anyway, so you may as well test the old one before doing the work.
u got to dremel a slot in it so a flathead screwdriver can unscrew it. u can replace it back with those bolts or get new ones. i switched mine to allen heads to make it look cleaner. u have to turn the key on and test the blk n red wire i believe for 4.5-.5 volts then tighten it down make sure u put it back int he way it came out the lil spring will ave tension it it thats how it knows where the throttle is as u push the pedal.
I currently driving my 1996 Honda Civic EX Automatic Coupe. Lately I've been noticing that when my car accelerates from a complete stop, it won't go as in like stepping on the gas lightly, it will take it to about 1.5k rpm and stops.. When I push the gas pedal slightly harder, it jumps to 2.3k-3k rpm right away from 1.5k rpm. It happens quite a lot lately. I don't know what's the problem, no CEL
anyone? I'm driving this car daily and it is dangerous to other drivers behind me when I accelerate from a complete stop since it will suddenly drop rpm to low and then it will take a few second before the rpm suddenly jumps to where it suppose to have been. And it is also hurting my MPG by a lot.
it almost sounds like the transmission clutches slipping until line pressure builds. and when it does build enough the computer senses it is time to shift. what was the condition of the fluid. was it dark? and was there much material in it?
I don't have any tools for that.
