Is a 93 integra t bracket the same as a 98 integra t bracket
I have a b18a1 swapped eg hatch, and I am in the process of getting rid of my ls trans in favor of a b16 tranny but the t bracket holes are lined up but just too low to thread the bolt in even with all the prying in the world. Any helps or thoughts would be much appreciated thank you!
Re: Is a 93 integra t bracket the same as a 98 integra t bracket
They are not the same.
If your using the T bracket from the B16, it's quite possible it's from a 96-00 civic which will never fit.
If so, use the bracket you had originally
Are both the LS and the B16 transmissions HYDRO versions ? Integra brackets are slightly different between a manual and automatic version. Photos of what worked before and what you are trying to use now would be very helpful. Post them please.
