2001 ITR Trans. gear lockout?
Old 06-19-2013, 12:20 PM
jamesschmidt82's Avatar
Default 2001 ITR Trans. gear lockout?
Past couple days my clutch has been pretty squeaky but grabbing just fine. All of a sudden today (driving normal just giving it gas to pass someone) 4th and 5th gear locked out. Then I pulled over and started running through the gears with the car off and then on. It almost felt like I had to re learn where my gears are. None the less I can get into all forward gears (no grinding or other noise) reverse is still locked out and the positions feel odd. Like my whole plate shifted. I tried going first to revers and down the latter. Nada. Any idea what may be causing temporary or full gear lock out?
Old 06-19-2013, 12:58 PM
TunerN00b's Avatar
Default Re: 2001 ITR Trans. gear lockout?
Broken / worn engine / transmission mounts could cause that.
Old 06-19-2013, 01:05 PM
Hope that's what it is, wish I wasn't in the middle of the woods in Michigan so I could get her up on a lift. Thanks for the response
gsaldana10
Honda Civic (2001 - 2005)
01-17-2017 07:20 AM
01civicTN
07-19-2015 02:11 PM
!moops vs moors!
04-13-2007 08:47 PM
Jimmy
50
10-08-2006 04:07 PM
Quick Reply: 2001 ITR Trans. gear lockout?
