Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
L15B7 - Ticking after Cam Sensor Code
Old Feb 20, 2026 | 06:46 AM
SoUmlaut's Avatar
Default L15B7 - Ticking after Cam Sensor Code
Hopefully someone can give some insight, since I've hit my ceiling with this one. 2021 Sport, L15B7, tune, 100k miles. Started as a infrequent Cam Sensor A code, somewhere around 3.5-5k RPM usually, and would cause the car to slightly buck and go into limp mode. Final time it happened, the car developed a tick at the top left corner of the valve cover (exhaust cam area) that tracks with RPM rise/fall. Shut it down and been wrenching on it since. I tried replacing the chain guides and tensioner, car started up but still had the same issue. Online AI keeps going cam phaser or valve/lifter issue - but I'm not interested in an endless parts chase. Some rockers definitely have more play than others, but I don't know what's acceptable or if it could even be the issue. Same with valves, still need to check with gauge. I will be replacing the timing chain this time around, so guess that will rule out any chain slap. Anyone have any thoughts/ideas?
Old Feb 24, 2026 | 11:12 AM
SoUmlaut's Avatar
Default Re: L15B7 - Ticking after Cam Sensor Code
Bump, still looking for an opinion
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
heinrichranches
K Series
Aug 7, 2013 03:30 AM
DTR1
Aug 4, 2013 04:53 PM
type-GGSR
K Series
Apr 19, 2013 10:16 PM
