Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Shift light?
Old Jul 11, 2006 | 02:27 PM
Fnote's Avatar
Default Shift light?
Aparently the 06 SI has a built in shift light. I've never seen mine light up, nor know how to use it. I know-RTFM right? I'm just curious if anyone has seen this? If so how do i use it?
Old Jul 11, 2006 | 02:39 PM
tooann's Avatar
Default Re: Shift light? (Fnote)
shift light activates when you redline your car. i think it comes on around 7500 rpm-8000rpm
Old Jul 11, 2006 | 05:37 PM
Jay2005's Avatar
Default Re: Shift light? (tuanxvu)
what in the hell are you doing...at least redline before shifting...for me its a message to shift.
Old Jul 11, 2006 | 06:26 PM
spoonlongblock's Avatar
it comes on at about 7200rpm and goes solid at about 7600 to redline. I see mine all the time
Old Jul 11, 2006 | 07:04 PM
Miracle's Avatar
Default Re: Shift light? (spoonlongblock)
Shift it on the fifth time you hear it bounce off the limiter. When the needle touches 9,000 5 times, go ahead and shift. Makes VTEC hit extra hard in subsequent gears.
Old Jul 11, 2006 | 07:12 PM
Demonis's Avatar
Default Re: Shift light? (Red_EM2)
Just so you know, the above post was a joke... if you dont know what the shift light is, im assuming you might not catch his sarcasm.
Mine seems to come on around 7,800 blinking, and stay on around 8,300rpm. It is located under your gas guage. Bring the car up to high revs in 3rd or 4th gear if you are not used to redlining and shifting quick, so you can learn to use the light if you need to. Then later, do it in 1st and 2nd.
Old Jul 11, 2006 | 10:14 PM
projectprelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Shift it on the fifth time you hear it bounce off the limiter. When the needle touches 9,000 5 times, go ahead and shift. Makes VTEC hit extra hard in subsequent gears.</TD></TR></TABLE>
hahahaaa...yea do that.
Old Jul 12, 2006 | 06:59 AM
Dee A Nine's Avatar
Default Re: Shift light? (projectprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">Just so you know, the above post was a joke... if you dont know what the shift light is, im assuming you might not catch his sarcasm.
Mine seems to come on around 7,800 blinking, and stay on around 8,300rpm. It is located under your gas guage. Bring the car up to high revs in 3rd or 4th gear if you are not used to redlining and shifting quick, so you can learn to use the light if you need to. Then later, do it in 1st and 2nd.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectprelude &raquo;</TD></TR><TR><TD CLASS="quote">...yea do that.</TD></TR></TABLE>
Old Jul 12, 2006 | 08:03 AM
Type X's Avatar
Default Re: Shift light? (Dee A Nine)
it also doubles as an alarm LED at night
FYI
Honda Crx
Jul 12, 2006 07:29 AM
Honda_hatch 96
Jul 15, 2004 06:51 AM
typerlover
Nov 18, 2001 10:11 AM
