Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
transmission problem help code p0730
Old Jul 8, 2013 | 10:01 PM
datsun71's Avatar
Default transmission problem help code p0730
I have a 2003 civic and it look like the transmission went bad, I drove the car and it wont go over 40mpg on drive. and showing code p0730 gear ratio incorrect.
can it be my shift control solenoid or torque convertor
please help.
Old Jul 9, 2013 | 03:46 AM
fishman765's Avatar
Default Re: transmission problem help code p0730
It is not your torque converter...all that does it translate engine rotation to the transmission. Does your engine rev at high/low speeds when driving in normal conditions? When you get up to 40 is your engine revving very high?
Old Jul 9, 2013 | 07:58 PM
datsun71's Avatar
Yes when I drive the rpm does go high at low speed
So if not the torque converter then what can it be
Old Jul 10, 2013 | 07:17 AM
fishman765's Avatar
Hate to break it to you, but sounds like one of the transmission clutches may be stuck. You could get it checked out by a shop and see if they could fix it quickly, but it sounds like its either time to take it into the shop for a rebuild or drop another one in Have you ever flushed the tranny? How many miles are on it?
Old Jul 10, 2013 | 03:38 PM
datsun71's Avatar
No I haven't Just brought the car 2 month ago so idk if the previous owner ever flush the tranny
Old Jul 15, 2013 | 08:09 AM
fishman765's Avatar
Id get it checked out by a technician. It does not sound like a DIY job...unless you want to drop another tranny in.
HondaMax00
Jan 14, 2017 12:26 AM
07FG2
Honda Civic (2006 - 2015)
20
Jan 16, 2009 01:08 PM
SinglecamMitch
Dec 15, 2008 05:57 PM
ecu_fix
Jan 29, 2007 04:26 AM
BB[6]King
Oct 31, 2006 07:40 PM
