Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Keyless Entry Won't Function
Old Apr 16, 2025 | 08:52 AM
GoHardrGoHome's Avatar
5 Year Member
Default Keyless Entry Won't Function
I have a 2002 Honda Civic LX. The keyless entry worked fine until a month ago. I thought the battery in the key fob could be weak so I replaced it. The little indicate light on the fob comes on when lock/unlock buttons are pressed. I've tried numerous times to reprogram the fob. It will not enter the program mode. I've followed the instructions correctly.
I even went to the local wrecker and got two other Keyless Entry Modules to try. None would enter programming mode.
Any ideas on what could be causing the issue?
Old Apr 17, 2025 | 01:36 AM
vt05's Avatar
5 Year Member
Default Re: Keyless Entry Won't Function
my 05 lx was behaving similarly. The light on the remote does not necessarily mean a strong 2025 cell. Also I have read that the effective range of the remote decreases over time. These cars are 20+ years old now. I bought another fresh package of cells and when close to the car it worked again. Try holding the remote right near the driver side window, above the metal part of door. I made no attempt to reprogram.
Old Apr 17, 2025 | 05:01 AM
5 Year Member
I can be inside the car and it will not operate the door locks!
Old Apr 17, 2025 | 07:23 AM
pscarbor's Avatar
Is it the original fob or a replacement? I couldn't get a replacement I'd ordered to work on mine either. Since I bought it on Amazon I returned it and got a refund. I then ordered a Dorman fob which cost about twice as much as the one that didn't work. The Dorman programmed and worked perfectly.
So in my case the solution was to get rid of the cheap remote fob and buy a good quality one. Range is about twenty feet.
Old Apr 17, 2025 | 07:31 AM
5 Year Member
I am using the same key fob. I also had two other fobs in the house that I tried to program. None of them worked.
When I first tried to re-program the fob that I previously used successfully, the car sounded like it would go into programming mode (door locks would click) after I did the ignition/push button cycle thing TEN times, but yet when I tried to lock the doors, I was unsuccessful. It no longer clicks the door locks after 10 cycles.
Old Feb 24, 2026 | 01:45 PM
razer17's Avatar
Check the wiring on the door hinge there may be a broken wire.That was my problem at least....
Old Feb 24, 2026 | 02:05 PM
5 Year Member
Thanks for the advise. In my situation, a new key fob resolved the issue.
myhondatechID
Nov 2, 2023 06:39 PM
Noel Sale
Sep 4, 2021 06:21 PM
gunnralkajsfkla
Honda Fit
Apr 28, 2021 10:29 AM
mooneyestwo
Aug 6, 2018 12:58 PM
