Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Key Conversion
Old May 20, 2008 | 11:14 AM
DPHRULES's Avatar
Default Key Conversion
anyone know if you can change from a seperate key and 2 button fob to a flip key/switchblade key for a 2005 civic?
GOT IT SORTED..ORDERED 2 BUTTON FLIP OF E-BAY(£42).WENT TO LOCAL KEY CUTTING SHOP TO GET CUT(£5).CHANGED IMMOBILISER TRANSPONDER FROM OLD KEY(HAD TO SPLIT OPEN)JOB DONE.LESS THAN £50..BETTER THAN THE KEY AND FOB ANYDAY.
Modified by DPHRULES at 6:33 AM 6/14/2008
Old May 20, 2008 | 12:29 PM
D17alltheway's Avatar
Default Re: Key Conversion (DPHRULES)
doubt it... you would probably run into a immobilizer issue.. but then again anything is possible.. talk to a dealer
Old May 20, 2008 | 02:41 PM
toyomatt84's Avatar
Sanji
Default Re: Key Conversion (D17alltheway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D17alltheway &raquo;</TD></TR><TR><TD CLASS="quote">doubt it... you would probably run into a immobilizer issue.. but then again anything is possible.. talk to a dealer</TD></TR></TABLE>
Well, you can get the keys reprogrammed at the dealership, so it wouldn't be a problem. I've seen it done a few times before.
Old May 20, 2008 | 03:18 PM
skipbarber's Avatar
not all honda keys work on the same immobilizer system. to get a flip key to work youll have to gut one of your stock keys and the flip key and swap the transievers. depending on the flip key you get it may or may not work with your OEM keyless system too. It's been done on the rsx forums a few times. It's time consuming, but if you really want the flip key, have at it.
kingkau
Nov 6, 2008 11:31 AM
bb4 jdm lude
Apr 20, 2007 05:07 PM
pnoipj89
Jan 17, 2007 01:33 PM
B00STidDc5
Apr 17, 2005 08:39 PM
