Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help
Old Sep 27, 2006 | 03:55 PM
BeerKing's Avatar
Default Help
Im thinking about getting my car lowered. I know that i should be getting expensive coilvers. I was looking at the Tein STech Lowering Springs. The Stech springs lower about 1.3" and 1.4". If i put these one, do you think i would need to get camber kits or would it be fine?There is also the Htech springs which lower the car about 1" in rear and in back. Im trying to get rid of the wheel well gap between the tires and the wheel well. This is the site i found some of these on. It includes pictures. thanks for your help.
Old Sep 27, 2006 | 04:00 PM
brjhnson's Avatar
Default Re: Help (BeerKing)
go with the stech and no you will not need a camber kit. Unless you want one. Just more money you have to spend.
Old Sep 27, 2006 | 04:06 PM
Vantage's Avatar
I am lowered on H&R sports, which are 1.3" drop. I do not need a camber kit, but there is still MAD wheel gap. about 2 fingers front/back.
If u want no wheel gap, i think neuspeed sports would take care of it. 1.75" F 1.5" R
Old Sep 27, 2006 | 04:12 PM
BeerKing's Avatar
So i can use the STech springs and i wouldn't need a camber kit. Is this the same with all cars. I have a 03 Honda Civiv Ex.
Old Sep 27, 2006 | 04:41 PM
Vantage's Avatar
Yup you can do it, it will be the same on a 03 ex as my 01 LX.
Old Sep 27, 2006 | 04:57 PM
BeerKing's Avatar
Default Re: (B18a_CRX)
Cool thanks man.
Old Sep 27, 2006 | 05:19 PM
fventura03's Avatar
any drop affects the camber, meaning it's recommended to get a camber kit.
Old Sep 27, 2006 | 05:40 PM
Vantage's Avatar
I do reccomend it, but up to a 1.5" drop your camber will stay within OEM specs. anything after 1.5" and u will be outside the oem specs and camber kits are a must.
Old Sep 28, 2006 | 05:11 PM
BeerKing's Avatar
So is everyone positive about that?
Old Nov 18, 2007 | 07:41 PM
sloem2's Avatar
Default Re: (BeerKing)
how do u guys feel on tein s-tech vs eibach sportlines on koins for everyday driving
Old Nov 18, 2007 | 08:06 PM
Pnoymugen's Avatar
Default Re: (sloem2)
I've had s-tech's on my car for 3 years now on stock shocks w/o camberkit without any complications, but it doesnt mean that your shocks will last the same as mines has so far. freddy is right though, it's recommended that you get camber kit with any drop. IMO if you have the money, get a complete coilover kit there are quite a few out there for less than $1,000. my .02
Old Nov 18, 2007 | 08:20 PM
fitfreak3's Avatar
Default Re: (Vantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vantage &raquo;</TD></TR><TR><TD CLASS="quote">If u want no wheel gap, i think neuspeed sports would take care of it. 1.75" F 1.5" R</TD></TR></TABLE>
I agree with the nuespeed sports. I have these on my car and its one of the best riding springs
Old Nov 19, 2007 | 12:21 PM
oddmut's Avatar
Default Re: (fitfreak3)
my friend has an xb the old shape and runs on s techs and they've been riding fine. I prefer those over eibach springs.
also it is noted in other posts that if you drop your ride below 1.5 you will be getting into camber issues, but if you are not dropping it lower than 1.5 your camber won't be affected too much.
Old Nov 19, 2007 | 12:26 PM
imroadk1ll's Avatar
go for the stechs unless ur going to buy eibach sportlines from sears and if u do go for eibach make sure sears installs for free.
Old Nov 19, 2007 | 01:10 PM
sloem2's Avatar
Default Re: (imroadk1ll)
would my koni shocks affect wether i choose stech or sportlines?
Old Nov 19, 2007 | 01:12 PM
oddmut's Avatar
from my understanding I prefer coilovers because I don't like to mix match spring rates and strut rates. You can buy springs with high rates and struts with low rates and they don't match properly.
With coilovers they are matched perfectly.
edit: I don't think it would affect it. Then again I don't have too much data on that so bump..
Old Nov 19, 2007 | 01:38 PM
sloem2's Avatar
Default Re: (oddmut)
yea i agree with u on the coilovers. But a buddy of mine works for koni and i got their shocks for cheap.i dont want to spend alot on GC's cause i want a comfortable ride still on stechs or sportlines...so bump
Old Nov 19, 2007 | 01:39 PM
oddmut's Avatar
i would check the specs on the stech and eibach springs. Check with Koni and see if there shocks would ride fine with those springs.
Old Nov 22, 2007 | 09:50 AM
katzenjammer84's Avatar
If there was anything such as "doing it the right way" and just using springs, and you're absolutely sticking with stock struts, I'd recommend Eibach's ProKit. It doesn't drop much, but the spring rates are increased significantly and you'll notice a definite handling advantage.
On top of that, ProKits are known for being pretty easy on stock strut setups.
Old Nov 22, 2007 | 07:53 PM
DsevenEm2's Avatar
this been covered before.. pretty sure. but you have your answer now.. everyones sure about it.
dgmgsr
Oct 11, 2009 06:13 PM
mightyjoecivic
Suspension & Brakes
May 24, 2007 10:42 PM
BlueJdm
Jul 12, 2006 07:55 AM
BIGCU
Jun 8, 2003 07:35 PM
Understeer
Jul 28, 2002 02:44 PM
