Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Header question
Old Oct 21, 2007 | 10:37 AM
crazybluecivic's Avatar
Default Header question
hi ive just installed my new headers on my lx civic sedan non vtec so my top 02 sensor is short and i extended it no my check engine light is on and when i acellerate i hear like a little rattle air sputter noise can it be cause i have no cat now but i am planning to get one asap or can it be lose somewhere ........ im thinking its because the stock gasket did not fit so its leaking a lil and the check engine light might be on cause theres no cat now please help opinions
Old Oct 21, 2007 | 10:53 AM
toyomatt84's Avatar
Sanji
So, you're running an EX header on an LX?
If so, where did you mount the primary Oxygen sensor on the header? As well as the secondary Oxygen sensor?
Old Oct 21, 2007 | 11:32 AM
Slidin'Sidewayz's Avatar
Default Re: (toyomatt84)
I know what he done cause Ive done the same. The O2 sensor, primary is mounted at the flange on the down pipe, at the begining and then the secondary O2 sensor is mounted right before the rear flange and he has a straight pipe for a down pipe. I have the same thing on my car, its loud but because of no cat it stinks and your check engine light stays on.
Old Oct 21, 2007 | 12:02 PM
Default Re: (Slidin'Sidewayz)
ok i thought that to but i hear theres a way to trick the bottom o2 sensor and how can i get a perfect seal on the bottom flange
Old Oct 21, 2007 | 02:12 PM
yeahitsphilip's Avatar
Default Re: (crazybluecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazybluecivic &raquo;</TD></TR><TR><TD CLASS="quote">ok i thought that to but i hear theres a way to trick the bottom o2 sensor and how can i get a perfect seal on the bottom flange</TD></TR></TABLE>
there is a way to trick the second o2 sensor into thinking there is a cat. its a CEL eliminator.
http://www.inlinefour.com/blcelelad.html
Old Oct 21, 2007 | 03:47 PM
toyomatt84's Avatar
Sanji
Default Re: (yeahitsphilip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeahitsphilip &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.inlinefour.com/blcelelad.html </TD></TR></TABLE>
Which is just a Spark Plug Defouler that they've renamed for profit. Those things cost like $0.99 at typical auto parts stores.
Old Oct 22, 2007 | 06:02 AM
thats a good idea never knew it exsited because I havn't ever had a car like this one, so thats something I would like to spend .99 Cents on. lol
As far as that gasket not sealing up, I don't have a clue cause I have an EX and everything fits like a glove on mine, there mine came with a gasket and its just a triangular flange that meets with another and its a thin flat gasket, not sure about the model you have. Thats for the one at the rear O2 sensor, if your talking about the one inbetween the header and down pipe then you should be able to tighten it up enough to seal.
Old Oct 22, 2007 | 08:18 AM
recaroem2's Avatar
what header are you running for the lx. and dosent it make it sound ricey
Old Oct 23, 2007 | 08:25 AM
Default Re: (recaroem2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by recaroem2 &raquo;</TD></TR><TR><TD CLASS="quote">what header are you running for the lx. and dosent it make it sound ricey</TD></TR></TABLE>
yeah i hate to say it but it sounds ricey as panda exspess lol i hate it but it could be cause right now i have no cat tisk tisk im going to get a highflow one and the spark but defolers etc etc and most likely im going to have to make a custom gasket for the bottom of the headers burn but yeah ricey like hell and loud and since theres a leak theres a little air sputter like a mucle car its funny as hell
Old Oct 23, 2007 | 09:00 AM
I have an EX so no problem fittin anything on mine, but mine doesn't sound Ricey, mine has a deeper tone to it because I got a muffler thats like 4.5-5" round and gives it a really good smooth tone, unlike those ticked off bumble bees I hear running around.
Old Oct 23, 2007 | 09:18 AM
i know i hate it lmao angry bumble bee with the stickers that add h/p lol yeah im going to take it back to the guy and tell him to put a bigger muffler cause mines little and its not letting the air out smooth now its ricey it was deep when i had the stock manifold but now its ricey in high rpms
Old Nov 3, 2007 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
Which is just a Spark Plug Defouler that they've renamed for profit. Those things cost like $0.99 at typical auto parts stores.</TD></TR></TABLE>
OK NOW HERES THE BIGGY do i have to drill out a little deeper into the defouler due to the fact the o2 tip does not fit cause i tried doing a plug and play this morning and to my demise it didn't fit in
so should i drill some extra space
and should i extend it by 2 defoulers of just one
and should i do top o2 and bottom o2 or just the bottom
Modified by crazybluecivic at 8:52 PM 11/4/2007
Old Nov 4, 2007 | 02:15 PM
MrXclusivE's Avatar
Default Re: Header question (crazybluecivic)
I know how to get rid of the CEL after you do this swap, disconnect the sensor wires and run it for a day with no sensors! your cel will be on, then connect the sensor wires and run it for a while and BAM! your CEL will go off and stay off. Worked for me lol
Old Nov 4, 2007 | 02:20 PM
Default Re: Header question (MrXclusivE)
have you checkd to see if it still throws a code
Modified by crazybluecivic at 4:35 PM 11/4/2007
Old Nov 4, 2007 | 06:24 PM
MrXclusivE's Avatar
don't know probably not, since if it triggers a code the light would be on.
Old Nov 4, 2007 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrXclusivE &raquo;</TD></TR><TR><TD CLASS="quote">don't know probably not, since if it triggers a code the light would be on.</TD></TR></TABLE>
I DUNNO ....... i think im just going to end up drilling a lil more gap for my spark defoulers ill keep ever one posted
Old Mar 5, 2008 | 01:09 PM
vbkapousidis's Avatar
hey slidin what muffler and headers are you using to get that deep tone?
Old Mar 5, 2008 | 09:00 PM
toyomatt84's Avatar
Sanji
Default Re: (vbkapousidis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vbkapousidis &raquo;</TD></TR><TR><TD CLASS="quote">hey slidin what muffler and headers are you using to get that deep tone?</TD></TR></TABLE>
Please use the Private Messaging system that's here on Honda-Tech, instead of reviving dead threads for personal information.
Click this image under the user's name: ""
Old Mar 7, 2008 | 08:35 AM
Sorry 'bout that Toyomatt
Old Mar 22, 2008 | 08:23 PM
over_'s Avatar
like at autozone? or where? what section would it be at?
pinche wikitoyomatt
--as a footnote, this should have a section in the FAQ i think. Spark plug de-foulers and their purpose
Old Mar 22, 2008 | 08:31 PM
toyomatt84's Avatar
Sanji
Default Re: (OVNI_CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OVNI_CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">
pinche wikitoyomatt
--as a footnote, this should have a section in the FAQ i think. Spark plug de-foulers and their purpose </TD></TR></TABLE>
I know for a fact, that Checker AutoParts has them.
Old Mar 22, 2008 | 08:52 PM
over_'s Avatar
checker=advance, i think, reguardless- i found this try tomorrow and get it, if they arent closed for easter
http://www.partsamerica.com/Pr...=3124
thanks again toyomatt
Old Mar 23, 2008 | 09:26 AM
over_'s Avatar
came upon this yesterday:
http://www.civicforums.com/for....html
went today and bought
$3.97 at Advance Auto Parts
just need to modify the opening on one of them to accomidate the sensor tip
Modified by OVNI_CIVIC at 10:43 AM 3/23/2008
b18c4door
Apr 23, 2005 06:17 PM
krazykaraboo
Jul 24, 2004 10:51 AM
Silver99CivicEX
Aug 7, 2003 11:43 AM
robbieshonda
Mar 2, 2003 10:06 AM
