plug information.
plug information.
ok im going to be replacing my spark plugs. im going to go with nkg. are our spark plugs under those black squares on the valve cover? and why are they sealed up so well compared to other hondas plugs? what do i gap the plugs to? anything special i need to know? ive changed plugs on cars before but im paranoid about this one kuzz i owe 14,000 dollars on it and i would hate to do sumthing wrong and screw it up.
Re: (toyomatt84)
go to a store and ask them for the factory spark plugs for your car. They should come pre gaped and always put in what you take out.
Re: (brjhnson)
See the coils below the wire loom cover that says "Honda VTEC" on it? See the bolt holding it to the valve cover? Undo that bolt with a 10mm socket, and undo the wiring harness underneath the loom cover.
You will then be able to replace the OEM plug. Repeat 4X, and reverse the process for reinstalling.
Re: (toyomatt84)
buy OEM plugs
as for the gap use whatevers stated on the emissions label on the hood.........(oem plugs are pregaped, just check em try not to adjust them)
70383roadrunner
Honda Civic (2001 - 2005)
03-20-2018 10:57 AM
