Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 civic questions
Old Nov 4, 2009 | 11:35 AM
KdF's Avatar
KdF
Default 2003 civic questions
I've done some searches.
And everything contradicts itself.
I just have a few questions.
I'm looking at getting an auto 2003 em2
What do I need to make it standard.
Besides the tranny. Do they make an aftermarket mount or can i just modify mine
Next up
K20 swap vs Turbo.
Don't try to convince me its 3k for a turbo kit..
The only thing I am worried about is the tuning.
Assuming its 1400 for a turbo kit, which is better.
I am not looking for a 9 second car but I do want something more than 117 whp.
Whats best to tune it with it.
Would the greddy emanage be fine.
Old Nov 4, 2009 | 12:43 PM
Igaly's Avatar
Default Re: 2003 civic questions
to go from auto to manual besides the tranny u need axels and a ecu from 5 speed civic it will mount good
Old Nov 4, 2009 | 12:59 PM
Igaly's Avatar
ok d17 boosted vs k20
d17:
no a turbo kit does not cost 3k lol its around $900, unles u just wanna run 5lbs psi u need low compression pistons, tune the ecu, get a better tps sensor, a turbo manifold ur gonna spend like 3k on that project if its well done u well have 230whp runnin 14's
k20:
u need motor, tranny, ecu, rsx exhust, rsx shift linkage and a couple more stuff ur gonna spend like 6k on this project and with k20A2, k20Z1, k20z3 runs low 15's k20A3 run 16's
u tell me wich is better u can k-pro both motors, thats another 30hp so u make a desicion
Old Nov 4, 2009 | 01:23 PM
It Wasn't Me's Avatar
Next up
K20 swap vs Turbo.
The FAQs has a link for Auto to Manual Conversion
Not sure if you've read any of these, so I'll just toss them out there. K Swap, and 305whp turbo buildup.
We also have THE TURBO THREAD - Boost for Noobies! which would be a good spot to ask turbo related questions if you can't find an answer somewhere in it.
Old Nov 4, 2009 | 02:02 PM
bomerman19's Avatar
heh $900 for a turbo kit lmao that might get you a turbo and a turbo mani fold but by the time you add up all the little **** like wastegate, bov, intercooler, and piping engine mangment, sensors, yeah it adds up quick if you want a reliable set-up it starts at 3500 and goes up that is not for big boost and forged internals.
you would be an idiot to by an auto and convert it to a manual just go out and by a manual and it will save you so much more money especially since your looking at switch out mounts, subframe, axles, shift linkage, trans wiring just like a turbo it adds up quick.
oh and these cars don't have 117 hp maybe at the crank but at the wheels it is more like 90 to 95 hp if you want a little more pep for cheap just get a stage 1 cam
Old Nov 4, 2009 | 03:07 PM
Igaly's Avatar
yea but i was giving him a roughly estimate u feel bro like u said, if u wanna gain bro do stage 1 cam and k-pro ur ecu....u be a gohst
Old Nov 4, 2009 | 03:45 PM
FijiBlueFG2's Avatar
Road House
Next up
K20 swap vs Turbo.
Save the trouble and buy a MT em2.
But really, if you're going to buy a k20, swap it in, turbo chage it, etc., you might be better off buying a used fg2. You can get one for about $14k-$15k. An em2 + k-swap will run you for at least $10k-$12k
Old Nov 4, 2009 | 04:41 PM
boxeocampeon's Avatar
a k20s gonna cost you like 6000. i would just boost your motor a turbo sounds nice for your car
Old Nov 6, 2009 | 06:33 AM
KdF's Avatar
KdF
Hmm. Any more ideas?
Old Nov 6, 2009 | 08:50 AM
_illmatic_'s Avatar
D17s are okay.....You can turbo them K-Pro, but another thing you have to think about when doing the turbo is reliability. Do you wanna be under the hood every week making sure there are no leaks and what not. The K20 is gonna give you a very reliable start that you can build on later to yield even better results.
Old Nov 9, 2009 | 09:14 PM
bomerman19's Avatar
turbo is very reliable but only if you take the time to set it up right and run proper engine mangement
Old Nov 14, 2009 | 07:08 AM
KdF's Avatar
KdF
Ill have proper engine management for sure. I'm just worried about not being able to hit past 225-250 horsepower. Plus all my research says to get thatmuch power I'll have to upgrade internals
Old Nov 14, 2009 | 10:34 AM
slowassd17's Avatar
andyman was boosting a stock bottom end making 300 hp, im not sure what the max power a stock head will squeeze out is but for some reason the number 245 is comming to mind. just throw a set of arp headstuds on for some insurance, and you should be pretty good. and your horsepower goals are very acheivable!
Old Nov 14, 2009 | 08:04 PM
KdF's Avatar
KdF
So this talk of boosting a d17 requires a massive built motor is non sense? That's whatvi was figuring. Surely it could put out 250...
Old Nov 15, 2009 | 05:01 AM
ourbloodykisses's Avatar
do it right, stop being cheap. build the motor so it can withhold.
Old Nov 15, 2009 | 06:21 AM
KdF's Avatar
KdF
There's no point to build a motor if it won't hit much more than what it already has. There's also no point to build it if it can handle 300 stock and I'm looking for less.
Old Nov 15, 2009 | 06:26 AM
dont build it then, when it blows you'll wish you did
Old Nov 15, 2009 | 02:07 PM
slowassd17's Avatar
i wouldnt push it to the max, however i would trust the stock block to hold enough boost to make plenty of power for a small fwd car. but if your trying to make as much power as possible build it for sure man
Old Nov 16, 2009 | 09:16 AM
bomerman19's Avatar
the rod bolts have been seen to stretch at as low as 7-8 psi but the usually really start to stretch around 11 psi. the block it self will hold what ever you throw at it but the rods can only handle so much and the can hold a lot less if it is un-tuned
hondapilot74
Jul 12, 2018 11:14 PM
josh's ep3
Dec 16, 2008 08:44 PM
Stevis42589
Oct 15, 2007 08:01 PM
josiah
Jul 14, 2004 08:35 PM
shpae
Aug 27, 2001 08:49 AM
