Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Overheating issues
Old 04-27-2020, 08:00 AM
mikeWho128's Avatar
Default Overheating issues
I have a 2002 Honda Civic EX that keeps overheating randomly I've changed out the radiator, thermostat and getting the same results mor often after I changed the thermostat. I cant figure it out PLEASE HELP!!! This is my daily driver and my only driver at the moment. Thanks in advance.
Old 04-27-2020, 11:11 AM
JimmyCreedog's Avatar
Default Re: Overheating issues
Remove the thermostat completely. Reinstall the housing empty. It's a band aid but it works. It'll give you till next winter to figure out the cause. With no thermostat, it'll take a while to get heat inside the car, but in the summer that's not really a problem.
Old 04-27-2020, 08:01 PM
JRCivic1's Avatar
Did you use a genuine HONDA thermostat ? If not, this is likely your problem. Removing the thermostat completely in some cases causes water to move too fast through the system, and thus, not providing the water enough time to cool when in the radiator. This can cause an overheating issue all on it's own.
Old 04-28-2020, 07:12 AM
I agree that the no-thermostat-solution is not ideal. I was just thinking about the increase in total thermal mass and that if OP's one way drive to work is less than 15-20 mins, the car will never even make it up to operating temps.
Old 05-03-2020, 04:02 PM
benchwarmer's Avatar
air pocket , disconnect heater hose by the thermostat and purge .
Squad1
10
10-18-2009 07:24 PM
JOSIE
03-08-2009 08:43 PM
flawless95
10-15-2008 06:08 PM
JDM_Silver
05-30-2007 09:03 AM
purple98ek
06-26-2005 04:38 PM
Quick Reply: Overheating issues
