2001 civic ex...dies in warm weather.
I had the problem last summer and fall when the temp was about 70 or above. Didn't drive it for a month or so and replaced the fuel pump relay and injector relays. Drove all winter with 0 problems. The second the weather hits low to mid 70s again...can with drive about 30-40 minutes and just dies. I have to turn the key to off...give it a second...and it will start back up.... the longer I keep it off, the further it will let me go before it dies agin. Yes it throws codes...but it is hella codes from it dying while in motion. I noticed last week that the fuel level was going crazy when it was dying giving me weird fluctuations from half a tank to full tank (it was full). So I replaced the whole dang fuel pump assembly. $260 later and it is still doing it.....I've done a ton of research and can't put a finger on what this could be. Any suggestions would be great.
Read up on the faulty electrical connections inside the ignition switch as your problem. I think there was a bad batch of them in your model year and possibly a TSB on it.
Yea, I have seen a lot of info on the ignition switch being a recall. The test for that is to wiggle the heck outta the key when it is running to see if it dies....mine stays running with aggressive wiggling. I don't see how the warm weather would affect that issue, though.
Also, please list every specific code. We may be able to figure something out from those.
unim21
Honda Civic (2001 - 2005)
Apr 1, 2012 06:58 AM
