wrapped headers
Old Feb 14, 2005 | 11:24 AM
ironlung78's Avatar
Default wrapped header
i wrapped my dc 4-1 brushed stainless header this weekend with 2" x 50' DEI header wrap. it took a lot longer to do than it looks, because i didn't want to run out
and you gotta pull it mad tight around the bends so it doesn't wrinkle up.
Overall i'm satisfied with the outcome, just need to buy some hose clamps to to fasten it along all 4 runners because they're wider than the stainless wire ties. Waiting for new bolts from Honda for the install!!!
Before
After
Modified by sidesi at 4:38 PM 2/14/2005
Old Feb 14, 2005 | 11:26 AM
Erik95LS's Avatar
Default Re: wrapped headers (sidesi)
Looks pretty good man. Are those regular plastic zipties?
Inspector Gadget's Avatar
Nice. I have always likes the looks of a wrapped header.
I know it is supposed to keep it cool, but how much does it accually help?
Old Feb 14, 2005 | 11:27 AM
ea_hatch's Avatar
it keeps the header hotter which makes the gases flow faster
Old Feb 14, 2005 | 11:28 AM
Sam P 27's Avatar
Old Feb 14, 2005 | 11:29 AM
Team Underground Teg's Avatar
I realize it helps in exhaust flow but I liked it much better before...
Old Feb 14, 2005 | 11:43 AM
fullraceacura's Avatar
Default Re: (Team Underground Teg)
looks good
after i get my new anr header and full exuast i will probably be wrapping from where the header meets the head all the way to the can
Old Feb 14, 2005 | 11:47 AM
Civicman86's Avatar
Default Re: (itr#xxxxlives)
Wont the zipties melt?
Old Feb 14, 2005 | 11:52 AM
untitledsn41's Avatar
Default Re: (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">Wont the zipties melt?</TD></TR></TABLE>
thats what i was thinkin... is the wrap sticky?
ViZ's Avatar
ViZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">just need to buy some hose clamps to to fasten it along all 4 runners because they're wider than the stainless wire ties.</TD></TR></TABLE>
Old Feb 14, 2005 | 12:08 PM
pacifico's Avatar
its header
Old Feb 14, 2005 | 12:10 PM
Phantastic's Avatar
nice clean job
alecjoesph's Avatar
Default Re: wrapped headers (pacifico)
looks good
Old Feb 14, 2005 | 12:17 PM
jakeiscool's Avatar
Banned
you can get heat resistant fasteners on any site that sells heat wrap.
Old Feb 14, 2005 | 12:18 PM
eg360B's Avatar
Default Re: wrapped headers (alecjoesph)
I dont know much about wrapping headers on All motor headers. I heard that when u put that on headers that the heat will crack it, like I said thats wut I heard. People said that is mostly for FI. Please Correct me if im wrong
Old Feb 14, 2005 | 12:29 PM
shortSHIFT's Avatar
you have to know how to wrap them w/ just the wrapping....no need for metal ties...looks good and its a + that the peice is stainless beacause the wrapping leaves burn stains on ceramic...and another thing about comments on here ^ ^ ^ never have i heard that wrapping is used for better exhaust flow on the pipes...(as if they dont get hot enough already) the purpose is to cool off ur engine bay for cooler induction and reasons like having components to close to the manifold like in race engines w/ high output....
Old Feb 14, 2005 | 12:35 PM
WrongWD's Avatar
apparently if you wrap everything evenly, then it wont crack. also ive usually seen people use metal hose clamps instead of plastic zip ties
Old Feb 14, 2005 | 12:36 PM
ThatsMyEG's Avatar
Default Re: wrapped headers (shortSHIFT)
ive been wanting to do this to my header nice post. how much does the wrap cost and whats it called...
Old Feb 14, 2005 | 12:37 PM
ironlung78's Avatar
Default Re: wrapped headers (Bolivian_Ef'r)
to answer all the questions....
i put the zip ties there to hold it until i pick up some hose clamps. i bought high temp stainless zipties (if you look at the collector those are stainless), but i think
that stainless hose clamps will fasten it better because they are much wider..
The wrap isn't sticky at all. its almost like wrapping your arm with an ace bandage but its thinker and doesn't stretch. I think its coated with something because my hands and nose were full of black $hit when i was finished.
I wouldn't suggest doing it to a ceramic header because the ceramic coating is designed to dissipate the heat and wrapping it will cause it to crack. **almost like wearing 2 rubbers at once**
The DEI wrap claims that it reduces under hood temperatures by up to 50% and i've even read that you can grab the header while running when wrapped.
So do the math... Cooler under hood temperatures= cooler intake air which = free horsepower.
743 Stunna's Avatar
im thinking of doing this in a few weeks, were should i be looking for wrap an how much does it run?
Old Feb 14, 2005 | 12:39 PM
Phil DeVtec's Avatar
Default Re: wrapped header (sidesi)
looks like you did a good job wrapping, now slap it on and try it out!
Old Feb 14, 2005 | 12:48 PM
ironlung78's Avatar
Default Re: wrapped headers (743motorsport)
i bought it on ebay for $36.00 plus shipping
do a search... DEI Header Wrap
its the black wrap 2 inches by 50 feet, and i used all but about 3 feet..
How I did it..
i cut (3) 8 foot strips, and did one at a time starting from the left most one in the picture. that leaves you with 18 feet. i then wrapped the last one and overlapped all 4 where they all bend together. No metal should show. This is a B16 Header
B18C_EJ8
Dec 8, 2006 05:10 AM
J-HAWK
Feb 6, 2006 09:45 PM
Krypto
Nov 23, 2002 03:39 PM
1stealthls
May 20, 2002 07:53 AM
Ryuji
Jan 28, 2002 03:42 AM
