To those with jdm front DC's....
Old Aug 23, 2007 | 06:26 PM
Casey's Avatar
Default To those with jdm front DC's....
Quick question. Im fitting my front bumper on which is actually a mugen but im assuming it will be supported the same way as stock or any other aftermarket. The bumper reinforcement bar shown below:
has little "tabs" on each side which you can see in that pic. Do you slide the bumper into the tab or sit it on top of the tab???
Old Aug 23, 2007 | 06:40 PM
Casey's Avatar
Default Re: To those with jdm front DC's.... (Casey)
nevermind. theyre meant to be bent up so that the bumper sits flush to the bottom of the headlights
Old Aug 23, 2007 | 06:50 PM
DSEA2's Avatar
you are not supposed to bend them up. the bumper slides into them.
Old Aug 23, 2007 | 06:52 PM
Casey's Avatar
Default Re: To those with jdm front DC's.... (SpoonDC4)
not according th mugen instructions.
Old Aug 23, 2007 | 06:54 PM
DSEA2's Avatar
oh well im pretty sure the stock bumper does. i dont know about mugen
pennies_hatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonDC4 &raquo;</TD></TR><TR><TD CLASS="quote">you are not supposed to bend them up. the bumper slides into them.</TD></TR></TABLE>
this is true. the bumper slides into them not on top of them
Old Aug 23, 2007 | 06:58 PM
Casey's Avatar
Default Re: To those with jdm front DC's.... (pennies_hatchie)
stock. i figured out it was different for the mugen
Old Aug 23, 2007 | 07:00 PM
Casey's Avatar
Old Aug 23, 2007 | 07:38 PM
opiumdaze's Avatar
probaby because mugen bumper is probably thicker so it mightve needed it to be bent up to fit in between
Old Aug 23, 2007 | 07:45 PM
Casey's Avatar
Default Re: To those with jdm front DC's.... (opiumdaze)
nah its not thicker, itll fit in there just fine. i believe its meant to sit on top for some reason, otherwise theres a large gap between the headlight and the bumper
Old Aug 30, 2007 | 07:50 AM
jvtec95's Avatar
That bumper support is height adjustable, you should be able to adjust the gap out. I have an OEM front bumper and had a large gap the first, I actually had to enlarge the slot in the bumper support to raise it high enough to get rid of the gap.
Old Aug 30, 2007 | 08:13 AM
red_crx's Avatar
Default Re: To those with jdm front DC's.... (jvtec95)
It will slide in between the metal fins....if there is a gap then adjust the bar with the tabs
g3teg97
Feb 2, 2013 10:48 PM
thino
Dec 9, 2004 12:40 PM
vtNaMeSe
Jun 10, 2003 03:31 AM
AamirCWITR
Sep 21, 2002 07:22 PM
