Tachometer Question
Old Jan 27, 2003 | 03:08 PM
Crono139's Avatar
Default Tachometer Question
A friend of mine is in the process of installing a tachometer. He has everything, but the green wire hooked in. The instruction manual says to connect it to the negative side of the ignition. He said it's too hard to connect it there. Is there anywhere else that it can be hooked up? Thanks.
Old Jan 27, 2003 | 03:10 PM
Chris y0!'s Avatar
Default Re: Tachometer Question (Crono139)
no, i think it has to be there so you can adjust the shift light.
Old Jan 27, 2003 | 03:22 PM
Crono139's Avatar
Default Re: Tachometer Question (Spoon Hybrid)
Actually, he doesn't have a shift light. He got one without it because he has an automatic. The main reason he got it was to see the RPMs, and then adjust other things. It's just a simple 3 wire tachometer.
Old Jan 27, 2003 | 03:28 PM
steve_s's Avatar
Whats so hard about getting to the ignition wire?
Old Jan 27, 2003 | 03:32 PM
Chris y0!'s Avatar
Default Re: Tachometer Question (steve_s)
3 wires?
power, ground, ignition.
all 3 wires can easily be found under the dash. remove 3 skrews nd your in.
Old Jan 27, 2003 | 04:18 PM
steve_s's Avatar
Get a probe, it makes it a lot easier.
[Modified by steve_s, 8:18 PM 1/27/2003]
Shaynepolevault
Lighting
12
May 27, 2008 12:56 AM
tommymoose
Audio / Security / Video
May 1, 2006 06:40 PM
ExplicitSpeed360
Dec 8, 2005 08:15 AM
I3iggy
Jul 28, 2003 06:38 PM
DJHan
Feb 10, 2002 10:54 PM
